4 Banger runs poorly when cold; which is the ECM temp sensor? - JeepForum.com
post #1 of 3 Old 04-08-2010, 07:17 AM Thread Starter
EABiker
My Jeep has become cold blooded; rough choppy idle, stalls. low power...until it warms up and runs fine, classic symptoms of an open choke on a carbed engine. Since I have throttle body injection, I know its because the ECM thinks the engine is warm, and has the mixture wrong. I've seen on this forum that the proper sensor can be hard to find. NAPA shows a coolant temp sensor, ( @ $79! ) , so I certainly do not want to get the wrong one at that price. I can unplug the each of the two to determine which goes to the ECM, and which goes to the temp gauge, but is the ECM one hard to find at the parts store?
EABiker is offline
post #2 of 3 Old 04-08-2010, 06:49 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I beleive that the coolant temperature sensor (for the ECM) is screwed into the side of the intake manifold.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 3 Old 04-08-2010, 08:01 PM
Mark05059
you need a 2 wired sensor if that helps.
http://www.autozone.com/autozone/cat...questid=106527
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
97 jeep wrangler runs poorly in the morning bkfranklin22 TJ Wrangler Technical Forum 1 05-27-2009 08:59 AM
97 TJ Runs Cold - why? suntzur TJ Wrangler Technical Forum 6 01-11-2009 10:10 AM
Cold=Runs Like Crap, Warm=Runs Good - Help! CheapSunglasses YJ Wrangler Technical Forum 9 11-24-2008 10:56 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
'97 4 banger runs rough - Fuel? Spark? rluening TJ Wrangler Technical Forum 3 01-28-2007 07:01 PM
