4.88 gear questions. - JeepForum.com
post #1 of 7 Old 12-03-2009, 10:04 AM Thread Starter
94WHITEYJ
My rear blew out last night.... it's stock so it has the 4.10... it has 33's and is very sluggish i was told if i put 4.88's that'll give me more power now all i have to do is put the new gears or i need a new rear entirely? also if i just need the gears can you link me to a site to purchase them?
94WHITEYJ is offline
post #2 of 7 Old 12-03-2009, 10:09 AM
4luck0
if you change ratio you will need to get them for the front and the rear..
4luck0 is offline
post #3 of 7 Old 12-03-2009, 10:12 AM Thread Starter
94WHITEYJ
ok can you link me to a site that i can get them from and i dont need anything else since the rear blew? just new gears and back together and im good?
post #4 of 7 Old 12-03-2009, 10:42 AM
94WorknProgress
gears are extremely technical to install. but if you are up for it it can be done, with much research. Randy's Ring and Pinion is a pretty respectable gear specialist. Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services.
94WorknProgress is offline
post #5 of 7 Old 12-03-2009, 10:58 AM Thread Starter
94WHITEYJ
im having my mechanic do it he knows he did it to his own jeep i just dont want to call and bother him again just replace the gears and im set?
post #6 of 7 Old 12-03-2009, 12:25 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
If it is just the gears that failed, you can replace them, as stated it is highly technical, I would not try it. But I would not spend a nickel on that D-35 anyhow, sounds like a good time to upgrade to a Ford 8.8.
Just my $.02
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #7 of 7 Old 12-03-2009, 12:35 PM
Louie4
I'm with these guys. You might want to go with something more stout than a D35. Then again I re-geared my D53 myself and I plan on running 33's but I know what the risk are and I carry spare shafts withe me. As far as new gears go, you'll need the master install kit that comes with new bearings, seals, etc. I also suggest replacing the outer bearings on the rear axle. Of course if you do one axle you need to do the other. (You don't absolutely have to but you can't use 4wd if you don't).
I have Yukon gears in mine and you can get a master install kit from any 4wd store and online.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Gear questions??? cyberwolf50 TJ Wrangler Technical Forum 4 07-26-2009 10:06 AM
Gear questions Polo YJ Wrangler Technical Forum 3 06-30-2009 09:22 PM
gear questions greta TJ Wrangler Technical Forum 2 05-21-2008 12:02 PM
SYE and Gear Questions erbizzle TJ Wrangler Technical Forum 4 04-20-2005 11:53 AM
Questions on What to Re Gear To rbowling TJ Wrangler Technical Forum 2 05-18-2003 02:44 AM
