4.88 and 33 trouble - JeepForum.com
post #1 of 5 Old 04-05-2013, 04:20 PM Thread Starter
stopper8
4.88 and 33 trouble
just finished putting my whole rig together...4.2, 5 speed and 4.88s and 33s. tooks its first ride and well it sucks 5th gear is revin up to 3k at about 45-50 mph is my speedo gear is correct, but other than that, advice from guys who have seen this?
stopper8 is offline
post #2 of 5 Old 04-05-2013, 04:24 PM
CrawlingForward
I run 4.88 on 32s, and I hit 3k at 60-65ish, I believe, so yours should hit it at probably around 65-70.
If you've got a smartphone, download on of the free speedometer apps (I use Ulysses) to verify your actual speed. If you haven't changed out your speedo gear, it'll definitely be off.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #3 of 5 Old 04-05-2013, 04:43 PM Thread Starter
stopper8
im almost positive i changed the speedo gear when i did the SYE kit but cant be 100%....and it definitely did not feel like 65...not even 50 to be honest but the app could give me another clue for sure
stopper8 is offline
post #4 of 5 Old 04-05-2013, 05:13 PM
mrdeath2000
with .85 OD you should be doing 70mph with 33's and 4.88's at 3000rpm.
in 4th you should be doing 40mph at 2000rpm, 50mph at 2500rpm and 60mph at 3000rpm
This is based on a 32.7" tire as a 33. The 4th gear info is best because it's always 1:1 for us 5speeders, cant be sure your 5th is the same as my 4banger.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #5 of 5 Old 04-05-2013, 05:24 PM
rykemc
Not sure if this will help you at all, but with my 4.56 gears and 35's at 70 in 5th gear I am turning around 2200-2300rpm. 4.0 with ax15. I am by GPS and the speed control signs they put on the side of the road about 2 mph faster on my speedometer than what those two say.
rykemc is offline
