4" or 5x7 lights on fairlead? - JeepForum.com
post #1 of 24 Old 03-17-2013, 03:34 PM Thread Starter
GermantownJeep
My fairlead came with light mounts on it, so I figured I'd throw a pair on there. Problem is space is tight.
I've got some 55w 4" lights that probably fit the space better, but I'd like to run 100w if possible. Do you think these 5x7's are too big? The bumper kinda blocks them. I'm torn.
1995 Wrangler Rio Grande: RE 4.5" Lift, 33" MT/R's
2010 Grand Cherokee Limited: Hemi, QD II, 30" Nitto Terra Grapplers
GermantownJeep is offline
post #2 of 24 Old 03-17-2013, 03:49 PM
pasinbuy
I may be more inclined to worry about enough fresh air hitting my radiator to keep my motor cool.
Looks to me that you have nearly covered your radiator.
pasinbuy is offline
post #3 of 24 Old 03-17-2013, 04:19 PM Thread Starter
GermantownJeep
Yeah I thought about that too. Another reason to stick with the smaller ones.
post #4 of 24 Old 03-17-2013, 04:33 PM
jsd1991yj
Do you have any pictures without the lights mounted on the fairlead? I think it would look better without them. Sometimes less is more.
jsd1991yj is offline
post #5 of 24 Old 03-17-2013, 04:45 PM
plym49
Put the smaller lights on the fairlead and the rectangular lights atop the stinger.
Or, keep the rectangular lights on the fairlead and lose the lights atop the stinger.
plym49 is offline
post #6 of 24 Old 03-17-2013, 04:53 PM Thread Starter
GermantownJeep
Here it is before I put the lights in the fairlead. It is less cluttered
post #7 of 24 Old 03-17-2013, 04:56 PM Thread Starter
GermantownJeep
I may give that a try this week.
post #8 of 24 Old 03-17-2013, 05:03 PM
plym49
Let us see how it turns out. I must say that regardless of how you decide to do it, the lights atop the stinger take away from the look. Maybe shop out the top lights to see.
Maybe you can lose the big lights top center, use the rectangular lights on the fairlead, and then try the little or the big round lights at the base of the windshield.
plym49 is offline
post #9 of 24 Old 03-17-2013, 07:23 PM
Noltz
YJ Wrangler
I agree. Forgive the quick and dirty shop, but this IMO looks much better. If you don't need those big lights, loose 'em;
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #10 of 24 Old 03-17-2013, 09:09 PM Thread Starter
GermantownJeep
I do kinda like that. Maybe I'll move the spots up to the windshield.
post #11 of 24 Old 03-17-2013, 09:30 PM
plym49
This.
plym49 is offline
post #12 of 24 Old 03-17-2013, 09:57 PM
Carlos14
The spots would serve you much better, higher.
Luck Favours The Prepared
Carlos14 is offline
post #13 of 24 Old 03-17-2013, 10:40 PM
Xpress
Don't worry about enough cooling air flow. There is a LOT of space for air to flow right on through, and if need be, the cooling fan will suck air through. Our cooling systems are overly efficient for a reason, so much so that we actually need a thermostat to allow the system to heat up to proper operating temperature for our engines to work efficiently. Blockage that far out in front of the radiator is not a big deal (I have seen these bumpers before and there is more open space than appears in the above photos)- like I said, the cooling fan sucks ample airflow through the radiator on its own.
All about that unibody life.
Xpress is offline
post #14 of 24 Old 03-17-2013, 10:41 PM
jsd1991yj
I myself like the look of the last picture with no lights on the stinger. I have that same bumper and i'm trying to figure out what light combination im going to use on it.
post #15 of 24 Old 03-17-2013, 10:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What do you have facing backward? Or to the sides? If you need more than four aux lights facing forward, you have the wrong lights.
Anticanman is offline
