4.5" RE shim ?'s - JeepForum.com
post #1 of 8 Old 10-26-2004, 06:44 PM Thread Starter
Nater018
Nater018's Avatar
4.5" RE shim ?'s
I'm just wondering what degree shims you guys use on you RE 4.5" extreme duty lift. I installed the 2" steel shims that came with the lift and even after the 1" TC drop, sye and tom woods shaft I'm still getting pretty bad vibes at 35-45mph. What size shims would you recommend/are you using on your lifts?
1994 BLUE YJ 4.0 5spd, RE 4.5 Extreme Duty w/ OLD MAN EMU shocks , WARN front/rear swing away bumper, Gibson stainless headers/Banks front pipe/no cat/Dynomax Super Turbo catback, BUSHWACKER cut-out fender flares, the list goes on...
Pics of
Member #2
"Man, I'd love to set up shop in her crotch"--Chuck
Nater018 is offline
post #2 of 8 Old 10-26-2004, 06:54 PM
phlex234
phlex234's Avatar
i use 4 on mine, maybe that will help, but i have BDS, i think most lift kits use 4
HI, my name is phlex234 and i approve this message because it's my destiny
Jeep 2.5 Low Output club member #2
92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder
phlex234 is offline
post #3 of 8 Old 10-26-2004, 07:29 PM
PhilipJ
PhilipJ's Avatar
You shouldn't need the TC drop with the SYE, if you have the appropriate shims anyways. I have the same setup and had to go up to 8 shims; no TC drop. For a while I had 6 installed with no TC and there was a hint of vibe, then I put in the 8 and it was about as smooth as stock all over again.
You'll probably have to hunt around online to find 8's though. None of the local 4x shops I checked had anything over 4. Also, the aluminum ones in the kit are a bit more pliable so once you torque down on the u-bolts, they bend a little and you might lose some angle. I've seen better processed aluminum ones that aren't nearly as bad, but your best bet is some steel shims if at all possible.
PhilipJ is offline
post #4 of 8 Old 10-26-2004, 07:51 PM
phlex234
phlex234's Avatar
8 degreee where you get those
phlex234 is offline
post #5 of 8 Old 10-26-2004, 07:55 PM
PhilipJ
PhilipJ's Avatar
A driveline/transmission shop happened to have them in downtown Seattle.
http://www.drivelinesnw.com/
Not sure if they do mail/net orders or whatever, I just went in and picked them up after calling all over the state. Mine were 'used' as they'd been taken off some other vehicle that they had serviced and upgraded.
PhilipJ is offline
post #6 of 8 Old 10-26-2004, 10:29 PM Thread Starter
Nater018
Nater018's Avatar
The Rubicon Express catalog has steel 8's for $29.95. I'll think I'll try those because I wanted to get rid of the TC drop for more clearance anyway. Thanks a bunch.
Nate
Pics of
Member #2
Nater018 is offline
post #7 of 8 Old 10-26-2004, 10:34 PM
phlex234
phlex234's Avatar
also you should get a tummy tuck, not calling you fat, from nth degree mobility
phlex234 is offline
post #8 of 8 Old 10-26-2004, 10:41 PM
PhilipJ
PhilipJ's Avatar
Ah forgot about the tummy tuck... also some taller motor mounts will help even out the entire drivetrain with the rear pinion quite a bit. Also helpful if your stock mounts sound like there's a squirrel orgy going on in there like mine do.
PhilipJ is offline
Shimmy Shim Shim dpr333 YJ Wrangler Technical Forum 1 09-18-2008 10:35 AM
Installing SYE - How much axle shim to use? (4" lift) Mark_ZZ3 YJ Wrangler Technical Forum 8 09-11-2007 10:30 PM
To shim, or not to shim.... 19OlllllllO41 YJ Wrangler Technical Forum 1 06-17-2003 11:15 PM
Sye Shim? ErikJordan YJ Wrangler Technical Forum 2 02-24-2003 07:55 PM
Shim Help!!! Lavacrawler YJ Wrangler Technical Forum 6 10-26-2002 10:26 AM
