4.3 swap has finally begun - Page 71 - JeepForum.com
post #1051 of 1069 Old 03-22-2013, 08:13 PM Thread Starter
YJames90
YJames90's Avatar
Originally Posted by pete1991YJ View Post
Got time for an experiment? What happens if you leave the PCV valve out altogether and just plug the hose directly into the cover? Ther should be a good stiff vacuum on that hose after all.
I can try that in the morning. Wont it suck oil? Or do i want to gut an old pvc valve and install it.
My 2.5 to 4.3 swap thread
YJames90 is offline
post #1052 of 1069 Old 03-22-2013, 10:17 PM
pete1991YJ
Could just gut an old valve, I don't think it'll suck oil - I've done it before. I'm just real curious why it isn't pulling out all the fumes. Is there enough fresh air getting into the other valve cover? Some of them used to have a filter inside the baffles looked kinda like a brillo pad. Maybe gunked up? Far as the PCV goes, it should rattle if its good. I used to just blow thru them with my mouth to test them. If there was any difficulty at all, just chuck it and get a fresh one for 3 bucks.
Thats how they used to do it anyway, fresh air went into one valve cover and the other cover had the PCV hooked straight into manifold vacuum. Dunno about the new engines tho, I'm outta date.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #1053 of 1069 Old 03-22-2013, 10:49 PM Thread Starter
YJames90
YJames90's Avatar
Now you have me thinking. THe other side has a hose going from the VC to the top on the intake opposite the injectors. I guess I should remove the hose off the VC and see what happens. didnt know that was a fresh air hose.
Pvc is brand new
YJames90 is offline
post #1054 of 1069 Old 03-22-2013, 10:58 PM Thread Starter
YJames90
YJames90's Avatar
This is what the original 4.3 looks like inside. Not sure if anything is cracked. Is it worth replaceing all gaskets and trying to fire it up or is there too much crap in there. Would it burn off the bad stuff and eventually run clean?.
YJames90 is offline
post #1055 of 1069 Old 03-22-2013, 11:39 PM
pete1991YJ
I would give it a good cleaning in a tub full of solvent or whatever and see. Every time I ever heard an engine crack it was a real noticeable bang like a firecracker. Yours doen't actually look too bad, just neglected.
post #1056 of 1069 Old 03-23-2013, 10:16 AM Thread Starter
YJames90
YJames90's Avatar
Thanks Pete!!
I pulled the hose off the drivers side and there was a grommet around the tube that looked like it was clogging it. Also it was pushed all the way down closing off the air flow.
Now something else,, there always is,,,,, Beleive it or not theres a tiny pin hole on the top of the valve cover I replaces next to the VC mounting screw closest to the fire wall. It seeps oil out, I put some exhaust sealent on it for now, probably going to pick up some JB weld
YJames90 is offline
post #1057 of 1069 Old 03-23-2013, 04:01 PM
pete1991YJ
Originally Posted by YJames90 View Post
Thanks Pete!!
Bingo, you just found the prob I think.. Could just tack or braze the hole shut, but why not swap a cover off the old motor, do you still have it?
post #1058 of 1069 Old 03-23-2013, 07:29 PM Thread Starter
YJames90
YJames90's Avatar
http://www.jeepforum.com/forum/attac...323_201352.jpg
YJames90 is offline
post #1059 of 1069 Old 03-24-2013, 02:16 PM
captainauti
im guessing you on the road again?
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #1060 of 1069 Old 03-24-2013, 04:12 PM Thread Starter
YJames90
YJames90's Avatar
Heck yeah I am!!! The muffler cement did the trick and I wheeled it hard all day yesterday!.Now the front diff cover and axle seals are leaking. Today I replaced the hood latches, fender flares, fixed the OBA and hooked up the winch cables. ( forgot to do this and got stuck in a bog yesterday, good thing I had jumper cables)
YJames90 is offline
post #1061 of 1069 Old 05-16-2013, 11:17 AM Thread Starter
YJames90
YJames90's Avatar
Update:
Cracked the flex plate and had to replace it.
This noise gave it away
I have a spare
Question,
The green wire B8 that comes off the computer and should be going to the AC pump to increase idle when the AC comes on. Can I use that to raise the idle for the AC pump that is for OBA ?
Do I just splice it into the power wire and it sends 12V to the computer ?
YJames90 is offline
post #1062 of 1069 Old 05-18-2014, 08:12 PM
captainauti
digging up your old thread. no answer about the green wire.
but you installed a true neutral plate correct?
was it for flat towing? where did you find it? and what tcase are you running now?
Capt. Nate
aka Scallywag
post #1063 of 1069 Old 05-24-2014, 06:57 PM Thread Starter
YJames90
YJames90's Avatar
Brand Omix-Ada
Manufacturer's Part Number 18676.32
Part Type
Product Line
Summit Racing Part Number OMX-1867632
UPC 804314030582
Works perfect for flat towing with the np231
http://www.summitracing.com/parts/omx-1867632
YJames90 is offline
post #1064 of 1069 Old 09-08-2015, 07:52 PM Thread Starter
YJames90
YJames90's Avatar
and its been sold for 3500
YJames90 is offline
post #1065 of 1069 Old 09-08-2015, 08:36 PM
lovett86
That's too bad, hopefully to fund another bigger and better jeep
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
3/4 ton axle swap has begun!!!! highrolrcustoms YJ Wrangler Technical Forum 97 01-10-2014 11:40 AM
5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 98 11-05-2012 09:26 AM
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 10:46 PM
Finally got my 8.8 swap done(well mostly done) jeeper87 YJ Wrangler Technical Forum 17 06-19-2009 10:37 PM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 01:33 PM
