4.3 swap has finally begun - Page 7 - JeepForum.com
post #91 of 1069 Old 08-21-2011, 05:13 AM Thread Starter
YJames90
YJames90's Avatar
They do. If you look closely at this picture theres two big green ones. This is an overhead shot of the club I belong to.
They have to be atleast 20 feet across
EDIT Theres 3, a green and white one too
My 2.5 to 4.3 swap thread
YJames90 is offline
post #92 of 1069 Old 08-21-2011, 04:46 PM Thread Starter
YJames90
YJames90's Avatar
Followed the charts that i have and Ive got nothing. No power to anything . Better luck tomorrow
YJames90 is offline
post #93 of 1069 Old 08-21-2011, 05:50 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
I always use the Painless Performance wiring instructions, and they never fail.
Here is a link to the Chevy TBI download. All wires are the same color, so should work a treat
http://www.painlessperformance.com/w...rchField=60101
Click on "manual" and it will walk you through every needed connection.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #94 of 1069 Old 08-22-2011, 01:04 PM Thread Starter
YJames90
YJames90's Avatar
Made a few calls today. I was thinking it all wrong. Hope to have the S10 harness running the motor tonight
YJames90 is offline
post #95 of 1069 Old 08-22-2011, 05:53 PM Thread Starter
YJames90
YJames90's Avatar
Well not running but turning over. One of my mistakes was i didnt have the bulk head connector bolted in all the was so i wasent getting a connection.
I turned the key and the guages came to life. Then cranked it and it turns over. I dont have any vac of fuel lines hookd up yet..
Back when I removed the 4.3 I broke the starter and had to replace it. THere was a problem installing the started from the get go like it didnt fit correctly.
Now when I turn the starter it makes a terrible binding noise againt the flywheel but turns the motor over.
Removed the starter and activated it to make sure its fully working correctly. It is.
Looking closer at the starter teeth they look to not match the teeth on the flywheel like they are too big.
This explaines why I cant get the starter to mesh in and bolt on the way it should.
Just the edges of the starter teeth have marks on them like they are pushing the flywheel just enough to turn the motor over.
Im taking the starter back to AZ tomorrow and hope to get the correct one.
Overall it was a sucessful day being that the Jeep has somelife back in it.
YJames90 is offline
post #96 of 1069 Old 08-22-2011, 07:06 PM
oldtime_ironman
Yah chevys had 2 different size flywheels with the corresponding starters, ever since the 1960's. One had 158-tooth flywheel, usually on small-blocks and the V6 the other (heavy-duty) had 163 teeth, usually on big-blocks and HO applications. Thing is that except for the teeth, they're the same and can get mixed up.
oldtime_ironman is offline
post #97 of 1069 Old 08-22-2011, 07:51 PM
1 ton yj
1 ton yj's Avatar
Are the ignition hot circuits hot in run AND start? I drove myself up the wall on a swap because of this one time.
1 ton yj is offline
post #98 of 1069 Old 08-23-2011, 09:50 AM Thread Starter
YJames90
YJames90's Avatar
I confirmed that I ended up buying the 9 tooth starter and need the 11 tooth one
YJames90 is offline
post #99 of 1069 Old 08-23-2011, 10:22 AM
oldtime_ironman
Bingo. The 11-tooth one corresponds to the small-block and V6 flywheels. It doesn't take as much torque to turn those over, as compared to the big-block and HO applications.
post #100 of 1069 Old 08-23-2011, 11:21 AM Thread Starter
YJames90
YJames90's Avatar
Thankyou very much !
YJames90 is offline
post #101 of 1069 Old 08-23-2011, 04:10 PM Thread Starter
YJames90
YJames90's Avatar
11 tooth starters are hard to find
YJames90 is offline
post #102 of 1069 Old 08-23-2011, 06:09 PM
oldtime_ironman
It maybe easier to start swapping some junkyard parts.
The "classic" starters (pre-1986) had 13 teeth IIRC those might work also and they're much easier to find. Off any pre-1986 small block or V6.
You might be able to make things a *lot* easier if you take a look at GM Performance Parts (factory official stuff)
http://www.gmperformanceparts.com
post #103 of 1069 Old 08-23-2011, 08:43 PM
Pmoreau
1970 FSJ Gladiator
Tried Rock Auto?
Paul
Pmoreau is offline
post #104 of 1069 Old 08-24-2011, 07:10 PM Thread Starter
YJames90
YJames90's Avatar
Bought a 9 tooth starter but its redesigned and recomended by the auto parts store. It bolted up very easy but theres another problem.
I has zero function.
THe meter shows power going to the starter when the keys turned to run.
Im bring the starter to autozone to get it tested tomorrow. Just another roadblock
YJames90 is offline
post #105 of 1069 Old 08-24-2011, 09:05 PM
oldtime_ironman
I'm beginning to think that a different parts store maybe a better idea. But I'm 90% sure you'd have better luck with a decent wrecking yard, the kind where they know what they're talking about. BTW, GM starters are fairly interchangable, you don't necessarily have to limit yourself to Chevy. Cadillac and Buick particularly come to mind if you have to go scrounging.
3/4 ton axle swap has begun!!!! highrolrcustoms YJ Wrangler Technical Forum 97 01-10-2014 10:40 AM
5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 98 11-05-2012 08:26 AM
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 09:46 PM
Finally got my 8.8 swap done(well mostly done) jeeper87 YJ Wrangler Technical Forum 17 06-19-2009 09:37 PM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 12:33 PM
