4.3 swap has finally begun - Page 51 - JeepForum.com
post #751 of 1069 Old 01-01-2012, 03:51 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Originally Posted by YJames90 View Post
No,,Good idea, thanks
Go back and check the base timing with the wire unplugged. I set Dave's at zero degrees advance, which is what Alldata called for.
You can then set the base idle again, following the long and drawn out procedure in the Alldata
After that, maybe clean the IAC valve and see if that all helps.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #752 of 1069 Old 01-01-2012, 03:58 PM Thread Starter
YJames90
YJames90's Avatar
What notch of the 3 notches do I want to be at for the timing?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #753 of 1069 Old 01-01-2012, 03:59 PM
oldtime_ironman
X2 What Leftlane said. Chevy's are pretty sensitive to the timing. It doesn't take much tweak to make a big difference how it acts. You normally set the base timing first, then hook it all back up. Then set the idle speed. Right now its "loading" the trans kinda like a drag racer, makes em run hot and like leftlane said things can get melted if it isn't right. After you got the base timing and idle speed, you can set the "fine-tune" stuff.
oldtime_ironman is offline
post #754 of 1069 Old 01-01-2012, 03:59 PM Thread Starter
YJames90
YJames90's Avatar
And I have to look up what one is the IAC and how to clean it. But first its time to walk the dog
YJames90 is offline
post #755 of 1069 Old 01-01-2012, 04:07 PM
oldtime_ironman
You are turning the dizzy to the left, I hope? That's what retards the timing.
post #756 of 1069 Old 01-01-2012, 04:41 PM
leftlanetruckin
XJ on 37's
Set it to zero degree's initially James. Then you can grab an extra COUPLE of degree's if you want or need it.
Alldata should have a good picture of the timing marks etc mate.
Martin
post #757 of 1069 Old 01-01-2012, 04:50 PM Thread Starter
YJames90
YJames90's Avatar
Spinning it clockwise is slowing the idle
YJames90 is offline
post #758 of 1069 Old 01-01-2012, 05:35 PM
oldtime_ironman
Too far advanced then. I would just start from zero and then do as leftlane says (I don't have the alldata for this particular one).
post #759 of 1069 Old 01-01-2012, 05:42 PM Thread Starter
YJames90
YJames90's Avatar
So its too far to the left?? I dont know how to fix it. Will read up on it tomorrow
YJames90 is offline
post #760 of 1069 Old 01-01-2012, 06:04 PM
oldtime_ironman
Turn it to the right (clockwise) to slow it.
post #761 of 1069 Old 01-01-2012, 06:40 PM Thread Starter
YJames90
YJames90's Avatar
Thats what Im doing but its as far as it can go without hitting
YJames90 is offline
post #762 of 1069 Old 01-01-2012, 07:05 PM Thread Starter
YJames90
YJames90's Avatar
why does my idle raise up when I tighten the hold down bolt?
YJames90 is offline
post #763 of 1069 Old 01-01-2012, 07:14 PM
oldtime_ironman
The hold down bolt usually bumps things a degree or two because the dizzy gears are spiral kinda like a diff. I used to just *barely* crack the bolt loose so that it needs both hands to turn the dizzy - tended to be more accurate that way.
post #764 of 1069 Old 01-01-2012, 07:23 PM Thread Starter
YJames90
YJames90's Avatar
For something being so simple it sure is confusng
YJames90 is offline
post #765 of 1069 Old 01-01-2012, 07:26 PM
leftlanetruckin
XJ on 37's
This.
It is simple James, Just have yo get it in the sweet spot mate
At least we dont have to worry about tone rings etc with these motors!
Martin
3/4 ton axle swap has begun!!!! highrolrcustoms YJ Wrangler Technical Forum 97 01-10-2014 11:40 AM
5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 98 11-05-2012 09:26 AM
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 10:46 PM
Finally got my 8.8 swap done(well mostly done) jeeper87 YJ Wrangler Technical Forum 17 06-19-2009 10:37 PM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 01:33 PM
