4.2L Oil Sending Unit - JeepForum.com
post #1 of 3 Old 11-03-2013, 07:07 PM Thread Starter
ferriolom
Hey does anyone know the OHM range for the oil sending unit? I am going to buy my last few gauges and already have a new OEM sending unit and it would be easiest to just match the new gauge to the OEM sending unit.
If no one knows this information I would settle for the size and thread of the sending unit.
Sorry for this, but I searched and can't find this information anywheres
Thanks!
ferriolom is offline
post #2 of 3 Old 11-04-2013, 08:23 AM
bpounds
bpounds's Avatar
You need to download the FSM (factory service manual) PDF. The link is posted here frequently, but I don't have it saved. A search will find it.
For the specific oil pressure sender, the values are:
0 psi = 1 ohm
40 psi = 46 ohm
80 psi = 90 ohm
Make sure you are getting 7.5 volts to the sender. If not, you may have bad wiring or even a bad gauge cluster. Pull the connector from the sender and check the voltage.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #3 of 3 Old 11-04-2013, 09:21 AM Thread Starter
ferriolom
I'm rewiring everything new. Thanks for the specifications!
