05-01-2012, 12:19 PM
#1
4.2L Intake Manifold Sensors
OK I am in the middle of a tear down on my 87. The Jeep has a Weber Carb, its been nuttered and the ECU has been removed. I want to pull any wiring and sensors that I no longer need. To that end I am trying to identify all of the Temp sensors in the intake manifold. I know what the CTO valve is and am keeping it but the other three sensors i am not sure?
One should be the sensor for the manifold heater (want to keep this one)
and I am not sure on the other two, as I have not found a good diagram for these. Any help would be appreciated.
Here is a picture:
Thanks again
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift.
Finished the rebuild!!! Just need tires/rims, Front Bumper and Seats.
My build thread: http://www.jeepforum.com/forum/f12/m...hread-1137667/
05-01-2012, 08:42 PM
#2
#1 is the coolant temp sensor. Can't help on 3 and 4. None of those were hooked up on mine
05-01-2012, 09:11 PM
#3
Pretty sure 3 is the knock sensor and guessing 4 is the manifold absolute pressure (map) sensor from ch 6 of the haynes manual
05-02-2012, 05:16 AM
#5
Thanks everyone, I forgot all about Dales great site  .
So if I am nuttered I should be able to pull both #1 and #3 correct? The ECU is coming out also.
05-02-2012, 08:09 AM
#6
You could pull #1, #3, and #4 if you wanted to. Several guys here don't run the heater, but I probably still would living in PA. But certainly #1 and #3 aren't doing anything for you anymore.
05-02-2012, 08:40 AM
#7
Ok Thanks That what I thought but always like to make sure. Yes I think I will keep the heater although I am not sure it even still works? I will have to figure out a way to test it. Thanks again for the help.
