4.2L Fuel Injection and Build - Page 9 - JeepForum.com
 4Likes
post #121 of 638 Old 05-01-2011, 02:53 PM Thread Starter
cevans87
1992 XJ Cherokee
Ok so last night I decided to add to my wilderness rack... Running out of room in the jeep so wanted to take advantage of the extra space I had on the bumper, this is my final product waiting on it to dry... Will post another pictures with it on later
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #122 of 638 Old 05-01-2011, 05:51 PM Thread Starter
cevans87
1992 XJ Cherokee
So its finished let me know what yall think... And its quick disconnect
cevans87 is offline
post #123 of 638 Old 05-01-2011, 06:00 PM Thread Starter
cevans87
1992 XJ Cherokee
Here is the pictures
cevans87 is offline
post #124 of 638 Old 05-29-2011, 04:56 PM
dieselcolt44
I'm doing a 4.0 head swap on my 90 Jeep wrangler. I have and auto transmisison in it, and was wondering if there were any bell housings that would swap onto it that have the cps window? It is the tf999/904 I think. Any Suggestions? Thanks
dieselcolt44 is offline
post #125 of 638 Old 06-06-2011, 08:21 PM
lclark2074
lclark2074's Avatar
the two relays and ic on the side of the battry do you know what thy are fore
night crew 226
lclark2074 is online now
post #126 of 638 Old 06-11-2011, 04:25 PM
dieselcolt44
Not sure, ill look.
post #127 of 638 Old 06-12-2011, 10:43 PM
lclark2074
lclark2074's Avatar
I found the anser to the relays one is for the AC the second is for the heater under the carb. hopefuly next week I will have the fule injection in.
night crew 226
post #128 of 638 Old 06-27-2011, 06:27 AM
unclewilson2
what about all the vacumn lines got a complete 95 harness to go with complete 4.0 in my 90 and have all yhe vacumn lines which are needed ? .......can i elimante most of them?
unclewilson2 is offline
post #129 of 638 Old 06-27-2011, 06:46 AM Thread Starter
cevans87
1992 XJ Cherokee
These are the ones you need...
Map sensor
Brake booster
Fuel pressure regulator
4wd storage bowl (underneath battery tray)
Rear valve cover ccv ( just put a small little air filter from the parts store on the front one)
Heater control valve ( comes out of firewall on drivers side)
You can make your own diagram and hook it up like you want as long as those have vaccum
cevans87 is offline
post #130 of 638 Old 06-27-2011, 06:51 AM Thread Starter
cevans87
1992 XJ Cherokee
Just added a new chrome gibson header, new timing chain, new clutch and hydraulic concentric bearing, and new flywheel yesterday... Runs smooth as crap now. Pretty straight forward although i had 20 pins betweens marks on my timing gears instead of 15 like the book said i should have but then again i also had 64 pins instead of the reccommended 48... Clutch feels a lot better and the header looks sick, exhaust note is so much cleaner and smoother now.... Benny from hesco told me on friday i needed to be careful with my new high volume oil pump as it is too much pressure and could kil the dizzy gear... So i will be keeping an eye on that. New thing to cme soon are new autometer gauages for the speedo and tach new front bumper and im going to modify my seat to fit better around my console
cevans87 is offline
post #131 of 638 Old 06-27-2011, 04:24 PM
unclewilson2
thanks i have about a dozen lines !
post #132 of 638 Old 07-06-2011, 11:59 PM
lclark2074
lclark2074's Avatar
do you now what the voltage on the check engine light is?
night crew 226
post #133 of 638 Old 07-07-2011, 04:25 AM Thread Starter
cevans87
1992 XJ Cherokee
12 volts from from a switched source and grounded by the ecm ( black and pink wire )
cevans87 is offline
post #134 of 638 Old 07-07-2011, 11:33 PM
lclark2074
lclark2074's Avatar
thanks that works good I got codes 12 computer is not pluged for 50 starts. code 41 i think witch is (alt feld not right yet)? and 55 end of codes
I have got the heep to fire but not run yet
night crew 226
post #135 of 638 Old 07-08-2011, 07:13 AM
Kman1983
1983 CJ5
Cevans87 do yo have a firewall bulkhead pin print out for a '91 YJ harness?
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
