4.2L Fuel Injection and Build - Page 35 - JeepForum.com
 4Likes
post #511 of 638 Old 05-16-2013, 03:31 PM
remmons
Originally Posted by voz View Post
You're a good man Remmons, most would have stuck their chest out!
I'm a square peg in a round hole!
I am humbled by your comment. Thanks.
Robert.
remmons is offline
post #512 of 638 Old 05-20-2013, 07:20 PM
voz
cevans87,
Just noticed you live in NC, Hmmmm, When you gonna wire my 4.0 into my rig?
VOZ™
voz is offline
post #513 of 638 Old 05-20-2013, 07:34 PM Thread Starter
cevans87
1992 XJ Cherokee
When ever you want
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #514 of 638 Old 05-20-2013, 09:16 PM
voz
I'm in Clayton....
VOZ™
voz is offline
post #515 of 638 Old 05-21-2013, 04:11 AM Thread Starter
cevans87
1992 XJ Cherokee
Havelock
cevans87 is offline
post #516 of 638 Old 05-22-2013, 08:31 PM
sec2776
Cevans87
Great thread I have read this and started my own swap on my 88 yj. I have a problem and I think you can help. I swapped the head on the 4.2 that is in my jeep for a 91 4.0 cast#7120 the wiring harness is also from the same vehicle and AX-15 transmission and transfercase. I got it cheap, ( free). My problem is it will crank but not start. I have fuel pressure. What am I overlooking?
sec2776 is offline
post #517 of 638 Old 05-22-2013, 09:15 PM Thread Starter
cevans87
1992 XJ Cherokee
Its best to call, it could be several things... to list all of them would waste time and confuse. Feel free to call
cevans87 is offline
post #518 of 638 Old 05-24-2013, 06:42 PM Thread Starter
cevans87
1992 XJ Cherokee
Hey guys, I am now on facebook. If you want drop by and add me. It just got started so it will take some time to get everything up. I will have technical information such as wiring diagrams and parts listings for sale of what ever I come across.
www.facebook.com/jeep.surgeon
cevans87 is offline
post #519 of 638 Old 05-31-2013, 04:04 PM
Fishyj90
Great thread! its been alot of help. and thanks for the phone help.
the back story: i swapped a 93 4.0+auto from a ZJ into a 90 YJ 4.2+ax15. i had the standard 5 wires to fire and it would start and run for 2 sec and die. the ZJ ecm had a security module mated to it that i didn't pull when we pulled the motor and harness so the pcm would cut fuel after 2sec. i ended up swapping in a pcm from a 93 chreokee sport. fires and runs perfectly.
thanks cevans87!!!
Fishyj90 is offline
post #520 of 638 Old 05-31-2013, 11:03 PM Thread Starter
cevans87
1992 XJ Cherokee
A lot of phone calls here lately, hope I have taken care of everyone. Everyone I have talked to, the problems were resolved over the phone. Any feedback would be appreciated. Hope everyone is having a great spring/summer. I have been doing little things to the scrambler, hoepfully soon can starting rolling with it and switch out the 304 to a 4.0L.
sting1ray2 likes this.
cevans87 is offline
post #521 of 638 Old 06-03-2013, 11:42 AM
voz
Sir,
I don't do facebook.
But i will be contacting you once I have the 4.0 installed...
I'm sure my ******* will need help.
My buddy has a house at Emerald Isle, within walking distance to Bogue Inlet Pier.
VOZ™
voz is offline
post #522 of 638 Old 06-29-2013, 07:56 PM
Zorm
1983 FSJ Cherokee
cevans87, been forever again.
I have been s l o w l y working on this, http://www.jeepstrokers.com/forum/vi...hp?f=15&t=2860
Now in the wiring pahse. Looked at my SJ today and removed the old dizzy feed. Did not have that connected since I tossed the control module and stock dizzy for a HEI about 10 years ago.
So I still have 2 wires on the fender mounted starter sol that I need to see if I can get by without them or maybe one, since I will be moving to the 4.0 starter. The, I think 91 cherokee, engine harness I have has the large and small starter wires molded together, simple. The same harness has the alternator wires molded together also, seen here http://www.jeepforum.com/forum/f11/e...stion-1541378/
So I guess one of my questions is, should I try and find this alternator or keep the old one for the 258. (need to look at mounting options)
The other one is, since I have an old school A/C, engine does not change to compensate for A/C comp on, do I try and splice it into the A/C portion of the PCM so the new engne compensates or does it matter?
Some day this poor girl will get on the road.
thanks for any input gents
Zorm is offline
post #523 of 638 Old 08-09-2013, 05:08 AM
ALFDMAX
This is the best guide I´ve found about this swap, congratulations and thanks for your great job
I recently acquired an 89 4.2 YJ in very good conditions from the point of view of body and chassis but with a bulked 4.2 engine, so first thing I done was to buy a Renix 4.0L from an 89 Cherokee, I have all elements, including wiring harness, fuse box, ECM fuel lines, also with a auto trans AW4, I have about a week searching info about this swap because I was a little bit scared with electrical issues, but after I found this thread I became more optimistic and next week I will start with the swap.
Sure I will ask you for your help with some issues, hope a few questions because the thread contains every info I need, but always appears somethig and on the other hand, I´m from Romania and here we hav not all the sources you have there...
Thanks again for sharing this pretty good info
ALFDMAX is offline
post #524 of 638 Old 09-11-2013, 03:39 PM
mustanggarage
mustanggarage's Avatar
Hello I am fairly new to Jeep forum I hope you can help me with a couple questions. I plan to do the head swap and fuel injection swap on my 4.2 90 yj soon. I have researched it fairly extensively but some things I could not find an answer to.
the first is I am considering do a cam swap at the same time. I rebuilt a 4.0 in a cherokee that I had planned to swap in to the jeep but I have since decided to just swap the head since the 4.2 has less than 70,000 miles on it. I will keep the 4.0 shortblock wrapped in plastic till I need it. anyway my questions involve the cam and valvetrain. I bought a comp cams xtreme energy cam that was recommended on this site for the 4.0 and I was wondering if there is any reason it would not work in the 4.2. the applications chart at summit racing indicate that it should work so I believe it will, which brings up my second question. should I use the new lifters and pushrods I got for the 4.0 or does the 4.2 have different size lifters and pushrods. it is very difficult to find this information. I appreciate your help.
My yj:
mustanggarage is offline
post #525 of 638 Old 09-18-2013, 07:54 AM Thread Starter
cevans87
1992 XJ Cherokee
Hello everyone. Just wanted to stop in and give an update. Although I do not have the 90 Wrangler anymore, most of you know I have an 81 Scrambler. I was contacted by the guy who bought the wrangler and was informed that he was wheeling on the beach and forgot to cut the electric fan on and cracked the head. Stupidity is all I can say. Lately I have been searching for a upgrade for my brakes on the scrambler. I replaced the rotors, pads, shoes and wheel cylinders but could not find a good power brake setup for cheap. I tried an aftermarket unit a local guy had, it worked but would lock the brakes as soon as you touched the pedal. I was not willing to purchase and install a needed valve to lower the pressure from the corvette master cylinder. So after a little more research of which not much information was available, I decided to shoot from the hip and install a booster and master from a 1993 S-10. All I can say is WOW. Better than the brakes on my 08 Commander. I can lock up 33's very easily. The booster is a dual diaphram and not much was needed for the install. It bolted right up to the stock cj / yj braket, the only modification was welding the old cj booster eyelet to the new s-10 eyelet at 3.75 inches in total length from booster base to the end of the rod. Everything went together fine and bled very easily.
cevans87 is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
