4.2L Fuel Injection and Build - Page 34 - JeepForum.com
 4Likes
post #496 of 633 Old 03-25-2013, 08:49 AM
Que89YJ
Brandon is your fuel pump manually switched?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #497 of 633 Old 04-03-2013, 08:31 AM
BrandonReed2001
No I wired it up to the fuel pump relay thats tied to the ignition switch. I figured that part out now i am always keeping 40 psi. Now my problem is that sometimes i have weak orange spark at my plugs or sometimes i dont have spark at all. Usually to get it to spark it has to be boosted off. I have replaced the whole distributor and plugs. I am going to pick up a Crankshaft sensor today. When i quit working on it last night i went from sometimes having spark to no spark and not enough pawer to make the fuel pump run. I dont know whats going on.
BrandonReed2001 is offline
post #498 of 633 Old 04-03-2013, 05:30 PM Thread Starter
cevans87
1992 XJ Cherokee
Brandon, call me... pm sent, que89yj leave my thread alone and stop replying to everyone, your not helping as much as you think and keeps me from getting updates to my email to answer questions
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #499 of 633 Old 04-03-2013, 05:31 PM Thread Starter
cevans87
1992 XJ Cherokee
Brandon, pm wont send. Call me 4345820148
cevans87 is offline
post #500 of 633 Old 04-10-2013, 10:47 AM
EgulAye
1980 CJ5
cevans87, this is a really great thread. I've read about the first 18 pages so far. As it happens, I have a co-worker looking to scrap a '92 Cherokee Laredo that has the 4.0L HO and an automatic trans. He's asking $200, I gotta haul it off myself, and soon. I've already learned enough to know this is a great deal, I pick the Jeep up in three days (Saturday). There are a few particulars that I think I need to track down before I can make the swap.
I'm currently driving a 1980 CJ5 with what must be a special order engine... It's the 258 low compression version with a 1bbl carb. Now, my CJ5 is a 1980 and the "B" engine code is in the VIN even though it shouldn't be an option. I believe I've figured out (with the help of the forum) that my stroke is 3.90", giving me a compression ratio of 8:1. The issue arises that I've got a T170 3-speed in the Jeep now, but could also put in a T176 4-speed. I have both and all the hardware. If you would prefer I could PM you the specific details, rather than polluting your build thread.
Love the thread,
Thanks
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #501 of 633 Old 04-10-2013, 02:54 PM Thread Starter
cevans87
1992 XJ Cherokee
You can pm or call me
cevans87 is offline
post #502 of 633 Old 04-10-2013, 03:44 PM
Que89YJ
Sorry Cevan. I didn't see you on in such a long time I thought you bailed. Glad to see you back posting and following your thread. I will bail on the thread and leave it alone. It is a great thread.
Que89YJ is offline
post #503 of 633 Old 04-10-2013, 07:02 PM
EgulAye
1980 CJ5
Originally Posted by cevans87 View Post
video of my shift indicator lights
http://www.youtube.com/watch?v=X0v5w...ZhUsQJ22S8i3QU=
Red = Reverse
Green = Drive
you can wire Park, Reverse, Neautral, Drive (Not Overdrive), and 1-2
OverDrive has no connection between wires, the ecm see's it as an open circuit (which it is) which means I cannot put a light in
You could wire each of the other positions to a SPDT relay (single pole, double throw) and then wire the OD light through each of the normally closed contacts in series. Then it will only light if none of the other conditions exist, and as soon as one does it will go out. Half a dozen relays is quite a few to get another light, but if you want the light you could get it...
Half a dozen of these for less than $30 and a box of spade connectors, golden!
Absolute RLS125-12-VCD Automotive Relay
2012 JK
EgulAye is offline
post #504 of 633 Old 04-16-2013, 07:05 AM
Zorm
1983 FSJ Cherokee
just a thought, would it be worth it to somehow put a chevy HEI dizzy in the mix or maybe the Ford TFI dizzy upgrade?
Zorm is offline
post #505 of 633 Old 05-13-2013, 01:30 PM
voz
I have been reading this thread, quite GREAT!
this is my own.. http://www.jeepforum.com/forum/f12/f...-swap-1478412/
Question I have is , I have a sending unit which I will stick in my fuel tank,, Where would I plug harness into?
I have a 89 ..
Thank You!
VOZ™
voz is offline
post #506 of 633 Old 05-13-2013, 02:53 PM Thread Starter
cevans87
1992 XJ Cherokee
Wire it to the same plug the old unit was hooked to, you have to add the power wire, its on the body side of that plug but not the pump side... your current harness has 3 going into the plug and only 2 going out to the sending unit
cevans87 is offline
post #507 of 633 Old 05-13-2013, 03:45 PM
remmons
X2 with cevans87. The wire has already been ran to the back, all you have to do is locate the Orange wire up at the fuseblock/bulkhead connector. This is what I had done. While you have the tank down, may I suggest that you replace the fuel lines. Make sure that you use lines that are rated for fuel injection.
Robert.
remmons is offline
post #508 of 633 Old 05-14-2013, 06:46 AM
voz
Remmons & cevans87 thank You Both!
I was planning on replacing fuel lines.
VOZ™
voz is offline
post #509 of 633 Old 05-14-2013, 10:09 AM
remmons
No, cevans87 deserves all the credit, for it was him who had helped me in my conversion. I'm just merely another tool in the box.
Robert.
remmons is offline
post #510 of 633 Old 05-16-2013, 12:57 PM
voz
You're a good man Remmons, most would have stuck their chest out!
I'm a square peg in a round hole!
VOZ™
voz is offline
19scooter79
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
