4.2L Fuel Injection and Build - Page 33 - JeepForum.com
 4Likes
post #481 of 638 Old 01-20-2013, 10:06 PM Thread Starter
cevans87
1992 XJ Cherokee
Head, motor, ecm, exhaust, intake, power steering, steering column, auto tranny, 231 tcase, fuel rail, injectors, tcu, crank sensor, cam sensor, distributor, coil, alternator, water pump, map sensor, iac, tps, coolant sensor and switch... Oretty much everything under the hood, motor will bolt right up, tcase tranny and steering column
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #482 of 638 Old 01-20-2013, 10:08 PM Thread Starter
cevans87
1992 XJ Cherokee
Dana 30 and 35 are 4:10 without changes I believe, get axles out of a 4 cyl Wrangler... 4:10 stock and bolt right up
cevans87 is offline
post #483 of 638 Old 01-20-2013, 11:18 PM
94chb
Originally Posted by Thump View Post
I have been reading this post for some time now and the information is overwelming and much appreciated. I have aquired a 1988 Jeep YJ, 4.2, 5 speed with 3.07 axle ratio. Has 162000 km and in pretty good shape other than some surface rust. I have changed the fluids throughout the drivetrain before doing anything else to see if the vehicle was worth rebuilding and everything is good.So far I have installed a 4 inch lift and new wheels with 33X12.5X15 YokohamaMTs,and replaced 2 worn U-joints. I am looking to do a head swap and add fuel injection . My question is, I have located a 1993 Cheeroke with 4.0, 5 speed, 200000km, that was wrote off in a rollover. What engine components from the cheeroke including wiring harness ,head,intake and exhaust manifold, distributor, will swap over to my YJ without to much trouble? Any breif step by step instructions as where to start will be very much appreciated? Also,what would be the lowest gear ratio I could go with and still keep the original axle cages? Thank-you
i would swap everything over from the cherokee into your wrangler, whole engine, trans, transfer case, wiring harness and computer. then you will need to install a grand cherokee water pump, belt, and a few brackets, why? because the cherokee has the clutch fan mounted on the side of the engine, the wrangler and grand have it mounted on the water pump in center of then engine.
94chb is offline
post #484 of 638 Old 01-21-2013, 02:46 PM
Thump
Just to confirm,, I will have to change out the flywheel from the 4.0 to my existing 4.2, correct? Both are standard transmission. If so, I would think is it easier to drop tranny rather than pull motor? That does the word 'dizzy' refer to and will I have to do that? Thanks
Thump is offline
post #485 of 638 Old 01-21-2013, 03:02 PM Thread Starter
cevans87
1992 XJ Cherokee
Yes flywheel needs to be changed, and dizzy means distributor... I usually pull the motor to do flywheels
cevans87 is offline
post #486 of 638 Old 02-18-2013, 12:11 PM
Collin89Sahara
I have a question op, would a 242 cam fit in a 258?
Collin89Sahara is offline
post #487 of 638 Old 02-18-2013, 06:43 PM
Que89YJ
The 4.0 crank can be used. It its short stroking. Not that cannulae with it. Try search on the forum.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #488 of 638 Old 02-19-2013, 06:36 PM
Collin89Sahara
Op, will a 242 CAMSHAFT fit in a 258?
post #489 of 638 Old 02-28-2013, 01:43 PM
Richie4x4
Cevans
I am new to the forum and spotted your thread. Its definitley making my stroker project seem earier. I am on the shopping list and research portion. spring time will be the actual go time. I will shouting questions allong the way if your around.
GREAT JOB
Richie4x4 is offline
post #490 of 638 Old 02-28-2013, 01:53 PM
Richie4x4
I have a whole 95 grand cherokee laredo from bumper to bumper as my donor. i want to do the efi head swap to a 88 yj 4.2. Any precautionary advice is well appreciated. (4.9 stroker attempt)
post #491 of 638 Old 03-13-2013, 05:12 PM
Zorm
1983 FSJ Cherokee
cevans87, do you, or anyone going through this thread, know if I can remove the autotranny wiring from stuff from my 91 engine wire harness with no ill effect? As on the first page of this thread. I am building a stroker, still building a stroker, for my 83 SJ Cherokee. I will be using my T176 so I do not need the tranny wires. I also do not need the cuze control and maybe some other connectors. I just need to know if I can take this stuff off without the ecm giving me fits. I know I need to ground one of the pins on the ecm since the engine harness and ecm came out of a automatic.
thanks for any info.
Zorm is offline
post #492 of 638 Old 03-13-2013, 05:54 PM
Que89YJ
Yes you should be ok.
Fault codes:
No Start:
Que89YJ is offline
post #493 of 638 Old 03-14-2013, 09:04 AM
remmons
Just an update. My '88 YJ is still running strong ever since my '93 XJ 4.0L HO conversion. It had no problems starting in the dead of winter in -27 deg temps.
Robert.
remmons is offline
post #494 of 638 Old 03-20-2013, 09:19 PM
BrandonReed2001
cevans87, Great thread it has helped make my swap much easier. I have a 89 wrangler and my donor is a 93 grand cherokee. I think i have everything wired right. I used a E2000 Fuel pump. I used the existing fuel hose from the tank to the fuel pump then i used the cherokee's fuel line from the output of the fuel pump to the motor. I can turn my switch on and the fuel pump comes on and goes off.(I kept doing it till the fuel pump quit coming on. Which i assume that means that the line is fully pressured.) I try to start it and it runs for 3 seconds and it is like is not getting enough gas. I can do the same procedure again same runs 2 to 3 sec and dies. What did i do wrong?
BrandonReed2001 is offline
post #495 of 638 Old 03-25-2013, 08:08 AM
Zorm
1983 FSJ Cherokee
going through this engine wire harness, I cut out my VSS, will wire that back in when I get the part that connects to the tranny. Also, there is a large resistor in the harness, do I need to keep that? So what I should keep is the VSS, CPS, TPS, MAP, the other sensor on the TB, coolant temp sensor, air intake temp sensor (think its located on the intake, I am going to mount this to the air box/cool air intake), and O2 sensor. As far as the power dist. piece (rectangle box) I use that for fuel pump relay and maybe what other things.
I was going to try and splice this 91 harness into my 83 harness but think now I would like to make a stream line harness with a few splices into my old harness.
thoughts welcome
also would like to see an answer to BrandonReed2001 E2000 fuel pump issue, I bought a E2027 I think.
Zorm is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
