4.2L Fuel Injection and Build - Page 32 - JeepForum.com
 4Likes
post #466 of 638 Old 08-05-2012, 05:27 PM
getbent01
1979 CJ7
got some ? about the wireing. I am doing this swap on my 79 CJ and am not sure what all needs to be hooked up or where it needs to be hooked up to. All of the mpi parts came from a 93 XJ. Any wire prints or pics would be great. Thanks.
getbent01 is offline
post #467 of 638 Old 08-06-2012, 12:28 PM
Que89YJ
Use these 2 threads to search the forum GB. Try posting up to a new thread if you have any questions:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
http://www.jeepforum.com/forum/f12/a...-forum-992517/
For pics just select the images selection at the top of the google page.
Que89YJ is offline
post #468 of 638 Old 12-30-2012, 09:20 PM Thread Starter
cevans87
1992 XJ Cherokee
Just wanted to check in a see how everyone was doing. Remember, I'm always here if anyone needs any help.
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #469 of 638 Old 12-30-2012, 10:16 PM
94chb
i havent had any issues with my Swap, i beat on it every weekend and still holding up great.
here is a recent video, not best quality but you get the point.
94chb is offline
post #470 of 638 Old 12-31-2012, 06:44 AM
Zorm
1983 FSJ Cherokee
still wating to get my 4.7 stroker back from the machine shop so I can put it all back together. I know I will come back to this thred a few times for reference. I was happy to find the wire diagrams you shot me in the first few posts of this for my SJ. I think the wiring will be the real work part of my build. Still need to get ford 24lb injectors and the larger throttle body since I will be sucking in more air with this engine. Got a few folks seeing how a stroker will work in a SJ.
Zorm is offline
post #471 of 638 Old 01-02-2013, 10:58 AM
aggiejon
1979 CJ7
Got mine all back together. Cannot explain the feeling of pure accomplishment that I felt when I turned the key on this thing and it turned over the very first time. WOW! Now I just need to finish a few loose ends, such as completing the alternator hookup and the exhaust.
A huge thumbs up to CEVANS87 on all his help to make this work!
aggiejon is offline
post #472 of 638 Old 01-08-2013, 07:02 AM
lakeobum
I recently finished this swap, thanks to the OP and all of the input from everyone else.
Two questions:
1. it is very cold natured at first start in the morning and after it sits a while, barely idles at 4-500 rpms. Did I miss something?
2. I still cant get rid of the CEL, i tried a resistor between the alternator field wire and battery +. I still have a code 41.
It is a 89 YJ 4.2 with 92 4.0 head and FI.
Any thought?
lakeobum is offline
post #473 of 638 Old 01-08-2013, 07:18 AM Thread Starter
cevans87
1992 XJ Cherokee
Ecm could be bad along with or tps or iac, just off the top of my head... I have had bad ecms do the same thing with idle and bogus code scans
cevans87 is offline
post #474 of 638 Old 01-08-2013, 04:28 PM
lakeobum
I actually have a spare ecm, I'll give it a try. The iac and tps both came on the junkyard inatke, might try to find a test orocedure for them too. Otherwise, it runs sooooo much better than the weber i had on it.
Used weber anyone??
Thanks,
lakeobum is offline
post #475 of 638 Old 01-08-2013, 08:08 PM
Que89YJ
Idle when decel is a missing vss. The alt. Why don't you swap and use the external setup from a late model? Cold start I would look at the cts and fuel pressure to see if pressure is bleeding down.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #476 of 638 Old 01-09-2013, 09:04 PM
Collin89Sahara
Specing out a list for a potential stroked 4.0l or injected rebuilt 4.2/ax-15 swap. This thread will be useful Is everything needed to complete a swap in your thread OP? I haven't the time to read every page.
Collin89Sahara is offline
post #477 of 638 Old 01-10-2013, 04:24 AM Thread Starter
cevans87
1992 XJ Cherokee
Yes, everything is listed
cevans87 is offline
post #478 of 638 Old 01-10-2013, 08:02 AM
Collin89Sahara
If I were to swap in a 4.0/ax-15, couldn't I just find a computer from 91+ wrangler?
post #479 of 638 Old 01-10-2013, 08:55 AM Thread Starter
cevans87
1992 XJ Cherokee
You could but the wiring harness is different I believe
cevans87 is offline
post #480 of 638 Old 01-20-2013, 09:53 PM
Thump
New to site
I have been reading this post for some time now and the information is overwelming and much appreciated. I have aquired a 1988 Jeep YJ, 4.2, 5 speed with 3.07 axle ratio. Has 162000 km and in pretty good shape other than some surface rust. I have changed the fluids throughout the drivetrain before doing anything else to see if the vehicle was worth rebuilding and everything is good.So far I have installed a 4 inch lift and new wheels with 33X12.5X15 YokohamaMTs,and replaced 2 worn U-joints. I am looking to do a head swap and add fuel injection . My question is, I have located a 1993 Cheeroke with 4.0, 5 speed, 200000km, that was wrote off in a rollover. What engine components from the cheeroke including wiring harness ,head,intake and exhaust manifold, distributor, will swap over to my YJ without to much trouble? Any breif step by step instructions as where to start will be very much appreciated? Also,what would be the lowest gear ratio I could go with and still keep the original axle cages? Thank-you
Thump is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
