4.2L Fuel Injection and Build - Page 30 - JeepForum.com
 4Likes
post #436 of 633 Old 06-10-2012, 08:51 AM Thread Starter
cevans87
1992 XJ Cherokee
The relay is that easy.... Just run a wire from the 8 gage black wire w/ white stripe to starter solinoid... Connect starter wire at bulkead to trip relay and poof , its magic
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #437 of 633 Old 06-10-2012, 01:30 PM
meangreeny
all voltages check out but it is throwing codes 22 and 25. Also i have a question, if i cut pin 30 and ground the ecu side, what do i do with the other end going to the pdc?
meangreeny is offline
post #438 of 633 Old 06-10-2012, 02:05 PM
Que89YJ
You do not cut pin 30. Pin 57 is the one you need to ground.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #439 of 633 Old 06-10-2012, 02:10 PM
Que89YJ
I guess I had it wrong. Pin 57 is the asd relay. Disreguard
Que89YJ is offline
post #440 of 633 Old 06-10-2012, 02:15 PM
Que89YJ
If the starter is turning it doesn't matter what you do with the other side.
Que89YJ is offline
post #441 of 633 Old 06-10-2012, 02:17 PM
meangreeny
do i ground both sides or just the ecu side of pin 30
post #442 of 633 Old 06-10-2012, 02:25 PM
meangreeny
yes it is turning, i have fuel but it will not fire, it was a running 4.0l 5sp yj that i was installing an aw4 into but somewhere have gone wrong
post #443 of 633 Old 06-10-2012, 02:51 PM
Que89YJ
So the asd and fuel pump relays are functioning on there own and pulling in when you turn the key?
Fault codes:
No Start:
Que89YJ is offline
post #444 of 633 Old 06-10-2012, 02:53 PM
Que89YJ
Also did you measure the 5 and 8 volts with the meter ground lead connection to the ground on the connector?
Fault codes:
No Start:
Que89YJ is offline
post #445 of 633 Old 06-10-2012, 08:49 PM
meangreeny
yes sensors were measured that way and the two relays come on with the key. I am starting to lose my mind on this swap, many,many four letter words today
post #446 of 633 Old 06-11-2012, 05:20 AM
wrangin_myNeck
Double post
wrangin_myNeck is offline
post #447 of 633 Old 06-11-2012, 05:30 AM
wrangin_myNeck
Hey, I just want to throw this out there bc I've read a few swaps where people had their dizzy clocked 180 out an it was firing on the exhaust stroke. After dealig with all the wiring it's easy to overlook that.
And the 2.5l pin out that was posted matches the 4.0?
post #448 of 633 Old 06-11-2012, 08:19 AM
Que89YJ
OK I am going to run the gambit of possible issues so keep in mind I am not sure what you have done with the entire build out so they are not meant to be insulting to you. Did you use the correct flywheel? The position of the sensor was an issue and you said you were slotting it, are you sure your sensor is close enough to get a good trigger? The VSS uses the same power as the cam/crank and if it shorts it will take out the signal from the cam/crank. Are the wires from the vss ok? When you ran the new fuel pump and fuel lines to the fuel rail for the higher pressure pump did you hook them up correctly to the fuel rail and tank? Possibly switched the supply and return? Do you have spark at the plugs? If you do did you pull the distributor and flip it 180 out? Also on your 2 fault codes, start by doing a battery disconnect for a long 10 count and see if they clear. If they do not clear then check the voltage for each one on the connector and the continuity of the sensors to the ecu. Do a real good cursory check of the ecu connector and the sensor connectors to make sure there are no loose pins. Take the backshell off the ecu connector and make sure nothing is shorted or loose.
Que89YJ is offline
post #449 of 633 Old 06-11-2012, 12:23 PM
meangreeny
Ok everything was existing all i am trying to do is interconnect the aw4 wiring into the existing yj harness. The two vss wires are currently not connected from the aw4 harness because it was a 2 wire vss in the 91 xj i used and my yj is a 3 wire vss. The flywheel is a 91 no renix and the crank sensor is the same on a 91 auto xj and my 92 standard yj. Somewhere in my interconnection I must have made a mistake or maybe i need to hook up the transmission vss wires and not my yj's harness wires. There cannot be much on the aw4 wiring that can prevent engine start up but somehow or other i am missing something
post #450 of 633 Old 06-11-2012, 03:08 PM
remmons
While this could be true, the 4.0L has an odd number of teeth, so it can't be turned a true 180 degrees. The only way to do this is by rotation the spark plug wires 180 degrees.
Two things that kept my Jeep from running after the swap was;
1) Spark plug wires had to be swapped around 180 degrees,
2) Security feature over ride. Locate the purple and white twisted pair of wires, cut them about six or so inches away from the PDC, and splice them together.
Here are my two posts on these.
Security wires. http://www.jeepforum.com/forum/f12/i...l#post10338886
Spark Plug wires. http://www.jeepforum.com/forum/f12/i...l#post10382288
Robert.
remmons is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
