4.2L Fuel Injection and Build - Page 25 - JeepForum.com
 4Likes
post #361 of 638 Old 04-07-2012, 06:34 AM
Terry1961
can you tell me if you can switch the computer from a 91-95 to the earlier 90 4.0 without changing harness?
Terry1961 is offline
post #362 of 638 Old 04-07-2012, 06:58 AM
Que89YJ
The 90 fuel injection was renix not Chrysler so no they are not a direct swap.
Que89YJ is offline
post #363 of 638 Old 04-07-2012, 07:18 AM
Terry1961
that means a harness change I am assuming
post #364 of 638 Old 04-07-2012, 07:43 AM
Que89YJ
The 90 never came with the 4.0l or mpfi. Are you sure the setup is from a pre 91 xj. That is what you would have if you are correct.
Que89YJ is offline
post #365 of 638 Old 04-15-2012, 04:08 AM
dirtyb
1981 CJ8
Has this been verified?
Originally Posted by remmons View Post
I cannot vouch for the GC, but on the XJ, all you have to do is twist the white and purple twisted pair together near the PCM. This will fool the PCM into thinking that the Security system is intact. This is what I had to do to my Basket Case, which is what I have been driving to work all this week.
I've done almost all of the mechanical parts of the MPI swap from a 1994 Grand Cherokee to my 1981 CJ-8 Scrambler. I'll start the wiring tomorrow, and honestly, I'm scared to death. Never did anything like that before.
So has anyone ever done a successful swap with a Grand Cherokee Laredo? Is bypassing the security system as simple as Remmons says? I understand that I have to also bypass the "Is it in park?" wires.
According to the VIN look up, it doesn't have an anti-theft
dirtyb is offline
post #366 of 638 Old 04-15-2012, 09:09 AM
JohnFM3
The only advice I can give is the obvious. Be careful of the wire placement. I did a MPFI on a 256 74 CJ. The head bolt studs got warmer than expected an fried the wiring harness. Which surprised me as my YJ was in the same spot with no issues.
Good Luck.
John Moore ~ Real Men Still Crawl...
97 XJ (Diablo) 4.0L H.O. w/AW4 4sp Auto Dana 30/Chry 8.75 2.5 inch Flowmaster Exhaust 4 inch Lift w/ 32inch tires & RS5000 Shocks
92 YJ (BOSS) 4.0L H.O. w/AX-15 5sp Manual, 231 TCase, Dana 30/8.8 (3.73) 2.5 inch Flowmaster R.E. 2 inch lift and 2 inch body lift for CJ clip
XJ
YJ
JohnFM3 is offline
post #367 of 638 Old 04-16-2012, 10:25 AM
remmons
When I was working on mine, I was to the point where I had most everything buttoned up. I had cranked on it many times with no results. I had gone through, checked, and rechecked EVERY wire that was related to ignition. It wasn't until I had discovered that the XJ that my PCM and wire harness came out of had a security feature. You will find on my link (in my signature), page 9, post #125 regarding the Security Feature. On my PCM (1993 XJ) the wires can be found on pin locations #26 and #46.
These two will be cut and spliced together.
http://www.jeepforum.com/forum/f12/i...l#post10338886 Post #146 (page 10) is where it all finally came together and the Jeep was able to run. http://www.jeepforum.com/forum/f12/i...l#post10382288 If you read through my thread you will see starting from page 6 through page 10 where I had tried everything to get the Jeep to run.
As you can see, I had went through heck to get this thing to run. So hang in there and keep trying, you will find the answer soon.
Robert.
remmons is offline
post #368 of 638 Old 04-16-2012, 11:19 AM
Que89YJ
Remmons..thats it.
Que89YJ is offline
post #369 of 638 Old 04-16-2012, 01:07 PM
remmons
Originally Posted by Que89YJ View Post
Remmons..thats it.
Thanks Q! I have you and cevans87 to thank for my Jeep running. Maybe between all of us we can get these guys Jeeps running too!
Robert.
remmons is offline
post #370 of 638 Old 04-16-2012, 07:46 PM
contdevelop
Great info! I plan to put the 4.0 head on my 258 but wanna keep the carburetor.
contdevelop is offline
post #371 of 638 Old 04-22-2012, 11:51 AM Thread Starter
cevans87
1992 XJ Cherokee
Ok Since I have been running out of little things to do on the Jeep and I was getting a little antsy... I have noticed that I had a small oil leak coming from the oil filter adapter housing... the piece the oil filter screws into. Since none of the parts stores around had any of the 3 orings needed to "rebuild" the adapter, i opted to get rid of the adapter all together.
Here are the steps, read all of them first before starting:
1. The Adapter Housing either has a female hex or TORX, the TORX is T60 and more common. I have 96 XJ 4.0 Block and it was TORX, for pre 91 motors it is a 5/8" Bolt.
2. Used a TORX Allen Wrench set that I had bought for the torx bolts all over the Jeep a few months back, and it worked great with a piece of pipe I had laying around as a breaker bar.
3. Remove the Battery cable so you do not kill yourself before going any further.
4. Work from underneath, I have 33" tires and could work under the Jeep very easily.
5. Suggest engine cleaner/steam clean the entire passger side of engine on top and underneath first, and if the bolt torx hole is plugged with mud and oil like mine, use coat hanger and spray with WD40 or something, scrape it out.
6. Getting that T60 L Wrench aligned was one of hardest parts, did so from below. It took me minutes to get it aligned and drop in. Used screwdriver to pry the elbow part to seat as deep as possible, very close to a bolt on frame.
7. Have oil pan ready, it will leak.
7B. Leave the Oil Filter ON the Adaptor, easier that way, only one drip to deal with.
8. Using the T60 Torx Allen and my breaker bar it broke rather quickly and with minimal effort, unscrewing the bolt took a few minutes because it is a Torx and hard to line up.
9. It will start leaking, have a pan under it. Let it leak till slows.
10. The perfect tool to back out bolt more after no longer high torque is a T55 L wrench, remembered it grabbed, much much much easier to align. If you wrench from outside under (away from block) you can do it while its dripping without getting oily.
11. Once the oil has drained, removed the assembly. You will see a roll pin inside the block, this was so the adapter housing would not rotate on its own. Remove this with vise grips and keep it in case you want to get the oring kit and put the adapter housing back on later.
12. Get the old oring off the block and clean the surface with a lint free rag.
13. Looking at the adapter housing, you will see that the side the oil filter used to screw into will have a nut on it, it is 1". Unscrew this thread adapter and then screw it into the block.
14. Put a little oil on the new filters oring and put the new filter on.
Even though the new filter is smaller, i have not noticed any difference in psi. I still have 75PSI oil pressure.
Here are specs on oil filter to use or use one similar:
Brand Fram
Manufacturer's Part Number PH3614
Part Type Oil Filters
Product Line Fram Extra Guard Oil Filters
Summit Racing Part Number FRM-PH3614
Oil Filter Style Canister
Height (in) 3.360 in.
Outside Diameter (in) 3.000 in.
Filter Bypass Relief Valve Yes
Relief Valve Open (psi) 9-12 psi
Anti-Drainback Valve Yes
Smallest Particle Filtered 20 microns
Thread Size 3/4-16 in.
Gasket Outside Diameter (in) 2.781 in.
Gasket Inside Diameter (in) 2.484 in.
Gasket Thickness (in) 0.203 in.
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #372 of 638 Old 04-23-2012, 10:16 AM
aggiejon
1979 CJ7
Well I guess I'll try this again.
About to get my engine rebuild back together and start on my Junkyard MPFI. I just want to check and make sure I have my ducks in a row before I start.
Background:
1984 258 Engine
1979 Jeep CJ7 Rewired with Painless Wiring system
2001 Cherokee Head, intake, throttle body
1995 Cherokee Exhaust manifold, MAP sensor, starter
1995 Cherokee ECM, wiring harness,
2001 Cherokee TPS, O2 Sensor
1995 Cherokee Flywheel & CPS sensor
1984 Bellhousing for T-176 drilled for CPS mounting
I am fairly certain that my 2001 sensors will not work with my 1995 harness/ECM. I did retain the PDC in the harness. I have read many many many forum posts ad nauseum until my head has spun and trying to pick out the true jewels of the swap. Due to the information overload, I just want to confirm that my head is thinking right:
Sensors needed:
TPS
MAP
CPS
O2
VSS
Any others that I have missed? Do the sensors interchange (2001-1995? OBDI-OBDII)
Perhaps a reiteration on the Jeep CJ wires that go to the wires on the new harness to make it run. How many actual circuits are retained in relation to the 30 pounds of wiring that is in the trunk of that underhood harness
aggiejon is offline
post #373 of 638 Old 04-23-2012, 01:04 PM
Que89YJ
The VSS needsd to be the 91 YJ so you can drive the mechanical speedo and still get the ecu the speed input. I am not sure about the sensors but i would cross check the numbers before I spent any money on buying new ones. The O2 sensor should be good if I remember correctly.
Que89YJ is offline
post #374 of 638 Old 04-23-2012, 04:31 PM
pete1991YJ
Sensors needed:
TPS
MAP
CPS
O2
VSS
Since your 1995 ECU is OBD1, the sensors should also be for 1995 or older. Since you need the combo VSS from a 1991, I would just get all the sensors for a 1991, those will work with your 1995 ECU.
Switching between OBD1 and OBD2 is just too hairy IMO, so you are better to stick with OBD1 between 1991 -1995.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #375 of 638 Old 04-23-2012, 05:49 PM
Que89YJ
Some sensors do cross over like the O2 sensor. I would spend a couple minutes on a site like auto zone and cross refrence parts between the model years. If they don't cross refrence then you are only losing a couple minutes. If they do you could save yourself a couple hundred dollars.
Que89YJ is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
