4.2L Fuel Injection and Build - Page 14 - JeepForum.com
 2Likes
post #196 of 625 Old 10-31-2011, 09:24 PM
94chb
hey thanks for everything, i finished my swap today and MAN WHAT A DIFFERENCE IN POWER. going from a 4.2 and auto to a 4.0 H.O. fuel injected and a ax-15. my jeep will spin 33's in 1st and 2nd. and bark 3rd.
during the winter i wanna pull my 4.0 out and drop the 4.2 crank and rods into it then set it back into my jeep.
ive got a build thread
http://www.crossedup4x4.com/apps/for...-mean-wrangler
oh and i ended up sellling that ub and frame for $500 with clear title. so i didnt have anything into my swap.
94chb is offline
post #197 of 625 Old 11-05-2011, 11:47 PM Thread Starter
cevans87
1992 XJ Cherokee
awsome man, glad to hear it !!!
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #198 of 625 Old 11-05-2011, 11:48 PM Thread Starter
cevans87
1992 XJ Cherokee
got 1 or 2 more things to get for the tranny swap, and then i will be starting that in a week or two as long as nothing else comes up in life, oh and I found out i'm about to be a dad again !!!!
cevans87 is offline
post #199 of 625 Old 11-06-2011, 07:47 PM
unclewilson2
been working 60 and 70 hours a week ! hope to get on my jeep this weekend !
unclewilson2 is offline
post #200 of 625 Old 11-07-2011, 07:12 AM
wanabejeeper
1987 YJ Wrangler
Cevans87, I recnetly replaced the 4.2 in my rig with a reman. I plan on doing the 4.0 HO head with mpfi swap on to my 4.2 about 2 years from now as part of a frame off. I will be gathering parts , axles shafts, lift kits between now and then. I read through the whole thread and a couple of things caught my attention. I noticed that the heads, intake and exhaust are "tuned" at the ~3200 RPM of the 4.0 Power band. Is there a suggested setup that would better suit the 2200 RPM powerband of the 4.2. What about injector selection? I really like the low rpm torque of the 4.2. I also intend to do port matching and polishing.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #201 of 625 Old 11-10-2011, 10:06 AM
unclewilson2
Is the bulkhead connector the same for a 90 as the 88 & 89 wrangler? Also heres the bulkhead connector from a 93 4.0!
post #202 of 625 Old 11-10-2011, 10:26 AM
unclewilson2
If the 91 4.2 is the same as a 90 4.2! only a5 and a6 needs to be switched? if so how does hesco make so much on thier wiring harness? bought the 95 harness on ebay 30 dollars shipped!
post #203 of 625 Old 11-10-2011, 10:28 AM
unclewilson2
I think i have info overload have to many pinouts! hahahaah
post #204 of 625 Old 11-11-2011, 07:01 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
'91 should be a 4.0L. I would think it would be more similar to a '93 or '95 harness.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #205 of 625 Old 11-11-2011, 06:13 PM
unclewilson2
went to beeman jeep dealer they didnt have a fsm for a 90 sahara ! guess im gonna have to buy one tks ....its hard to find the bulkhead connector for the 90.
post #206 of 625 Old 11-11-2011, 07:14 PM
unclewilson2
bought a 90 fsm and a 95 fsm !!!!
post #207 of 625 Old 11-20-2011, 09:30 PM Thread Starter
cevans87
1992 XJ Cherokee
sorry i haven't posted in a few weeks, been really really busy...
ok so i got the aw4 installed and it works great...
i went ahead over the few months that i had it on the work bench and put a new front seal, torque converter, pan gasket and filter in the thing...
also i "clocked" the transfercase so it would clear the skid plate and let me add that i did not use a clocking ring i just did it by sight...
the only thing that needed to be modifed was the skidplate for the new transmission mount which only took about 5 minutes with a drill...
my driveshaft sits at a better angle and all of the shaft is in the case instead of about only an inch...
i used the yj radiator ports for the tranny cooler which is how the radiator came anyways... regular radiator hose connections and then two inputs for tranny fluid.
things i had to have to make the swap happen...
tcu (transmission control unit)
aw4 transmission
np231j
transmission hoses
2.3 gallons of tranny fluid
a drill
now i also used the xj np231
the only difference between the xj and yj tcase is the 4x4 lever
if you use the on off the yj it works flawlessly.
alos everyone asks me about the shifters
i used the stock tcase shifter with a small modification which is just a bracket, and then used the xj transmission shifter, all under the same boot that covered the ax-15 and np231 from the factory... looks sweet
also everyone who has seen it say's well how do you know which gear your in, and for a jeeper who has been on both sides of the yj,xj scene... it's not hard for me to put it in drive and go, but then the thought of my wife driving it and hurting my baby because she doesn't know which gear she's in kind of scares me...
so with a little cross referencing i found that the nss on the aw4 sends a 12v signal to the ecm.... yay !!!
so i put indicator lights in the dash color oriented of course and used a common ground on all, then ran a group of wires through the firewire and hooked each up individually at the nsss connector on the right side of the motor... works flawlessly untill i destroyed my nss trying to put it back on after cleaning it early today... so a run to the junkyard hopefully tommrow will put her back on the road...
i have no complaints with the aw4, nothing was wrong with the ax-15 but the aw4 was given to me by a friend who had me do a fuel injection swap on his 89 sahara who got it when he bought the motor... he didn't want the tranny and was going to throw it away... a true jeeper see's promise in even the small things
i will say this for those who are on the fence... i have a lot more throttle responce, and torque output... maybe not the numbers to hold up my statement but i know i can burn the rubber off my tires now from a stand still when before i could only chirp
all in all it took about 2 days with the weather being as cold as it was... needed to come in every so often and get warmed up then spent two ciggarettes and 15 minutes trying to figure out where i was in the process again
i will get pictures of the swap posted soon... if anyone needs anything just let me know...
cevans87 is offline
post #208 of 625 Old 11-20-2011, 09:37 PM Thread Starter
cevans87
1992 XJ Cherokee
oh and for those who have posted and i have not responded, most of the time i am at work and my phone chooses to let me know when i have posts... here is my number if you have seen i haven't posted on someone's question please call me and tell me to get off my *** 4345820148
uncle wilson, i had 90 wrangler pinouts posted man i hope you didn't spend all that money waiting on me... the should be on the first two pages of this thread
cevans87 is offline
post #209 of 625 Old 11-20-2011, 10:27 PM
brentd711
I'm finishing a '93 2.5L swap into my '90 2.5L. Keeping the '90 gauges and sensors and have a question on the fuel pump and sender. I've got it wired right now to power the pump (from a '93) through the '93 harness (PDC) but that won't give me a gauge signal I can use, right? Do I have to run a separate wire back to the gauge?
brentd711 is offline
post #210 of 625 Old 11-21-2011, 06:45 AM Thread Starter
cevans87
1992 XJ Cherokee
Your guage wire is there, does not need a new wire...
cevans87 is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 03:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 07:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 06:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 08:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 02:02 PM
