4.2L Fuel Injection and Build - Page 12 - JeepForum.com
 4Likes
post #166 of 638 Old 09-07-2011, 08:57 AM
flyin8s234
cevans87,
So I have put about 3000 miles on my MPI 258 and have loved every single one of them, but recently i have been noticing some blue smoke coming from the tailpipe on start up and when i press the gas and the rpms jump. If i hold the rpm's up, i can't see the smoke. This problem just started after i got my oil changed, I'm not sure if that has anything to do with it; the shop put 5W 30 when i told them to use 10W 30 and I'm not sure if they used synthetic or not (i hope not) .
Any ideas?
Also, I haven't seemed to loose any power since the problem started.
Thanks
flyin8s234 is offline
post #167 of 638 Old 09-07-2011, 02:27 PM Thread Starter
cevans87
1992 XJ Cherokee
Blue smoke is most commonly seen in turbo asperated motors, its a mix of water and oil being burned in the combustion chamber... I would start by doing a leak down test on the cylinder head... Sounds like oil entering the chamber through bad valve seals and or maybe the water jackets didnt seal up quite good enough on the head... Just a place to start
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #168 of 638 Old 09-11-2011, 05:33 PM Thread Starter
cevans87
1992 XJ Cherokee
Updated Pictures !!! Where we stand right now !!!
2011-09-11 15.44.35.jpg   2011-09-11 15.40.00.jpg   2011-09-11 15.41.53.jpg   2011-09-11 15.45.08.jpg   2011-09-11 15.41.28.jpg
cevans87 is offline
post #169 of 638 Old 09-11-2011, 05:34 PM Thread Starter
cevans87
1992 XJ Cherokee
More Pictures
2011-06-25 15.16.09.jpg   2011-09-11 15.42.37.jpg   2011-09-11 15.43.25.jpg   2011-09-11 15.43.05.jpg   2011-07-12 19.14.59.jpg
cevans87 is offline
post #170 of 638 Old 09-11-2011, 05:36 PM Thread Starter
cevans87
1992 XJ Cherokee
Pictures
2011-09-11 15.43.44.jpg   2011-09-11 15.42.49.jpg   2011-05-06 06.36.55.jpg   2011-09-11 15.46.28.jpg   2011-09-11 15.40.38.jpg
cevans87 is offline
post #171 of 638 Old 09-11-2011, 05:38 PM Thread Starter
cevans87
1992 XJ Cherokee
Pictures !
2011-09-11 15.46.52.jpg   2011-09-10 21.43.48.jpg   2011-09-10 21.43.35.jpg   2011-09-04 03.16.52.jpg   2011-09-03 23.13.11.jpg
cevans87 is offline
post #172 of 638 Old 09-11-2011, 05:39 PM Thread Starter
cevans87
1992 XJ Cherokee
Pictures !!
2011-09-04 03.17.05.jpg   2011-09-03 23.13.11.jpg   2011-09-03 20.27.56.jpg   2011-09-11 15.40.23.jpg   2011-07-12 19.14.03.jpg
cevans87 is offline
post #173 of 638 Old 09-11-2011, 05:40 PM
rfredrik
1979 CJ7
Like I said, this is an awesome build. Your inbox is full and you were missing a digit.. lol
rfredrik is offline
post #174 of 638 Old 09-11-2011, 05:55 PM Thread Starter
cevans87
1992 XJ Cherokee
Thanks Man, 4345820148
cevans87 is offline
post #175 of 638 Old 09-13-2011, 11:09 PM
94chb
Originally Posted by cevans87 View Post
you will need to get the following
91-95 4.0L Head from cherokee
91-95 complete wiring harness (under hood and going to the tranny and xcase) from cherokee
Vehicle Speed Sensor for a 91 YJ
4.0L Flywheel (91-95)
91-95 ECM from cherokee and same jeep you pulled harness off of
Crankshaft Position Sensor From a 4.0L (91-95)
Distributor from a 4.0L (91-95)
Intake and Exhaust from a 4.0L Exhaust (91-95) Intake (91-2006)
Throttle Body and Injectors from a 4.0L (91-95)
Fuel Pump Part Number SP736H from Advance Auto (this is the complete unit, pump, hanger, and sending unit)
Theres a few other things but there small and you will probably have them laying around anyways...
You can keep your auto, you only need to change out the flywheel...
Also as far as the wiring goes... leave your old harness in and lay the new one on top and just connect what you need to run the fuel injection, this will leave everything else the way it left from the factory, gauges will still work, ignition and so on... you only need 5 wires to run the fuel injection....
ok i got ahold of a 93 cherokee, buddy is parting out and said i can have everything i need for $150, will i also need throttle cable,trans kick down cable and anything else you can think of i need to grab while im there? also will i keep my same setup with the serpintine belt or will i need to change everything over to v-belt?
94chb is offline
post #176 of 638 Old 09-14-2011, 07:38 AM Thread Starter
cevans87
1992 XJ Cherokee
Throttle cable yes, but it will have a lot of slack u need to take out,but will work...
Trans kickdown... I dont know you will provably have to fabricate something for that...
Grab anything you think u will need, all electrical, connectors, fuel filter bracket, cruise, vaccum hoses, steering hoses, anything you can really... Better to have it and not need it...
Oh and grab to map sensor off the firewall... U will need that
cevans87 is offline
post #177 of 638 Old 10-06-2011, 11:22 PM
lclark2074
lclark2074's Avatar
so i got a wild hair up my a$$ and decided recently to do a lot of junkyard upgrades... such as rear view mirror with map lights which is awsome... also since i have a cherokee wiring harness on my stroker, i decided to grab a electric cherokee fan and install it as a puller since i already have a pusher... works awsomely... and plugs right in... another cool thing i found was a retractable underhood work light from a chevy pickup... works like a champ...
now a few days ago we went home to see some family and virginia... me being the true jeeper i am... decided i would pack a bag with a few tools and hit the junkyard saturday morning to see if i could find some goodies...
and I did !!!!
i found a lifted JK that had been wrecked...
i snagged the electric swaybar disconnect, the aftermarket wheel spacers, the subwoofer, the front seats, and the AEV snorkle... and i know your thinking wow this dude hit the mother load... well after the parts were off i was on my way... came across a grand cherokee with the 5.9L, went to snag the alternator, and guess what... it was still there but it didn't look stock... it was a 250amp Powermate by Wrangler... I walked out and only spent $25 all together!!!!!!
So i got home and decided I would go ahead and put the *direct* swap alternator in... ummmmm not so fast.... what i failed to realize is that since my motor originally started life in a 1996 cherokee, it would in fact not bolt right up and i needed to grind some metal off the block and alternator mount.... after a few hours, she's is in and I'm happy to say she works ! i can cut everything on in the truck and never see the needle fall once... here are some pictures for those of you who want the bigger alternator...
the stock alternator on the 4.0L is a teeny 90 amp... for those of us who don't have tons of cash... you can go to the junkyard and snatch a alternator out of
136 amp alternator*:
1996-1998 Dodge B.Series Van - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Dakota - (PN:56027913AB Reman:R6027913AC)
2003-2005 Dodge Dakota 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
1998-1999 Dodge Durango - (PN:56027913 Reman:R6027913)
1996-1998 Dodge Ram Pickup - (PN:56027913 Reman:R6027913)
1998-2000 Dodge Ram Pickup - (PN:56027913AB Reman:R6027913AC)
1991-1998 Jeep Grand Cherokee - (PN:56005685 Reman:R6005685)
2000 Jeep Grand Cherokee 4.7L - (PN:56041324AC Reman:R6041324AC)
2001-2005 Jeep Grand Cherokee 3.9L, 4.7L, 5.9L - (PN:56041693AC Reman:R6041693AC)
150 amp alternator*:
1993-1998 Jeep Grand Cherokee - (PN:56041394AA Reman:R6041394AA)
160 amp alternator*:
2001-2005 Dodge Dakota - (PN:56029914AA Reman:R6029914AA)
2001-2005 Dodge B.Series Van - (PN:56029914AA Reman:R6029914AA)
wich feld termenal is + and wich termenal is feld control pin20 on the computer. sorry the pics didnot come thru
night crew 226
lclark2074 is offline
post #178 of 638 Old 10-07-2011, 09:38 AM
remmons
I have not followed on this build for a while now, so I will be in the dark on some of this.
I have performed an EFI conversion on my '88 4.2L by using a PCM, wiring, and fuel system from a '93 4.0L HO XJ. This is what I have learned in the process.
Are you using your 4.2L block? Are you going with the serpentine system or are you keeping the V-belt system? The reason that I am asking is this, The 4.2L engine is externally balanced, meaning that the flywheel and the Harmonic Balancer are weighted. The 4.0L engines are internally balanced, thus the flywheel and the harmonic balancer are not weighted, they are balanced. If you are keeping the 4.2L and the serpentine system, you will need to get an HB from an '88 4.2L that came with a serpentine system. You will also need to use the flywheel from the 4.2L as well. Other wise, you will be experiencing a rhythmic vibration from the motor like I am, which in time will destroy your motor. Unfortunately, I am running an AW4 automatic tranny, so there is no weighted flex-plate for my application that will work (that I am aware of at this time).
X2 on grabbing everything that you can. If you have the whole donor vehicle, this makes things a whole lot easier. I ordered a throttle cable for a 91-95 wrangler for my '88. It worked just fine.
Robert.
remmons is offline
post #179 of 638 Old 10-07-2011, 09:42 AM
remmons
I wanted to throw this in while I was thinking about it. Click on my link at the bottom on Project: Basket Case and go to page 13. There you will see where I am at on my project, and how I have run into some issues that need addressed.
Robert.
remmons is offline
post #180 of 638 Old 10-07-2011, 10:05 AM
94chb
thanks for the info , but i came across an easier cheapier route, i grabbed a 91 wrangler 4.0 fuel injected, 5 speed. for..................$500 and ive got the tub and frame sold for $300 so im only gonna have $200 into the whole swap from carb to fuel injection and from auto to 5 speed
and everything should just bolt up since everything is coming from a wrangler, heres a pic of what i got. everything is there but the rear end.
my 89 wrangler 4.2 came with the serpentine belt system, im gonna put the motor in my shed and rebuild it and put a 4.0 head on it during the winter and eventually put it back in my wrangler and keep the fuel injection system.
94chb is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection on the 4.2 Brandon_YJ YJ Wrangler Technical Forum 16 12-06-2008 06:47 PM
4.0 Fuel injection on 4.2 IJP2 YJ Wrangler Technical Forum 46 08-14-2007 05:18 PM
YJ- Fuel Injection nowlide YJ Wrangler Technical Forum 3 07-14-2007 07:56 AM
Fuel Injection Loomis4wheeler YJ Wrangler Technical Forum 4 05-28-2001 01:02 PM
