4.2L carter carb float? help! - JeepForum.com
post #1 of 6 Old 05-01-2013, 09:56 AM Thread Starter
Charles88yj
Hey guys, my brother recently got a 4.2L 89 yj, has the stock carb, the car is running good but when you are going downhill in the moment you stop going down and star going up the car turns off, and its a little difficult to start, then when it starts you can go up 3 hours and it won´t fail, just in the change of downhill to uphill, I heard this is about de float in the carb, how can I adjust this? is there any other problem that could cause this? thanks!
Weber carb, Nutter Bypass.
Mud-Terrain tires 33x12.50
SOA Lift and Rancho RS5000 Shocks
And thinking of lots more!
Charles88yj is offline
post #2 of 6 Old 05-01-2013, 10:52 AM
jbolty
jbolty's Avatar
I would start with cleaning out the idle tubes, it's a common problem.
http://www.jeeptech.com/engine/carter.html
http://www.instructables.com/id/Fix-...eep-cj-7-or-w/
jbolty is offline
post #3 of 6 Old 05-01-2013, 03:59 PM
Old4X
1990 CJ7
Yes the float is easily adjusted if that is the problem. It is done by bending the little tab on the pivot arm piece of the float. You remove the top of the carb to get to it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 6 Old 05-01-2013, 05:03 PM Thread Starter
Charles88yj
thank you! the idle is always good, so I don´t think that´s the problem, i`m gonna check this but it goes off when its running not when its in idle!
post #5 of 6 Old 05-01-2013, 05:08 PM
jbolty
jbolty's Avatar
Guesses:
Check the routing of the fuel hoses. If they are getting hot it might vapor lock.
Vacuum advance or mechanical advance in the distributor.
Is it an auto trans? If so maybe the torque converter is not unlocking.
jbolty is offline
post #6 of 6 Old 05-02-2013, 12:00 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
I know this Jeep, Charles is a friend. I would say start by adjusting the float level and cleaning the tubes... the Jeep is not auto, we need to do the timing properly as well, last time I timed it so we could start it after the nutter but I know we have to do it again. Jeep was parked for two years so in the beginning we were just trying to get it started and get it to burn some crap out of the system... now it is running much better and we can work on timing it more accurately.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
