4.2L Block Drain Plug Removal - tool? - JeepForum.com
post #1 of 1 Old 12-29-2008, 02:05 PM Thread Starter
Delta347
I'm doing a coolant change and was wondering what the tool to remove the block coolant-drain plugs is called or is. .
Will a socket with an extender arm on work with out the socket on the end so its just the square end?
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
Drain Plug Removal with Pics! SpydermanTJ TJ Wrangler Technical Forum 36 09-27-2014 03:09 PM
engine block coolant drain plug mrsneelock YJ Wrangler Technical Forum 1 11-03-2006 09:35 PM
What tool for the Engine block coolant drain plug? MJCIII TJ Wrangler Technical Forum 0 09-02-2005 02:19 PM
Coolant Block Drain Plug giallojeep TJ Wrangler Technical Forum 1 07-06-2005 06:07 PM
TJ Coolant engine block drain plug kaybone TJ Wrangler Technical Forum 1 07-22-2003 02:34 PM
