4.2 weber 38 - JeepForum.com
post #1 of 6 Old 02-17-2013, 02:04 PM Thread Starter
JCashen
4.2 weber 38
I just installed my new weber 38 and am in the process of getting the lean best idle. Problem is if I bottom out the mixture screws with the jeep running it makes no difference to how it udles. The idle speed screw is backed out so it doesn't touch at all.
I pulled a plug and it is was tan originally now it is pretty close to completely black.
I'm also running a mad street fire (no tach yet) and distributor set on 18r slot with lighter advance springs.
I've been reading the weber set up and tune discussion. If anyone can point me in the right direction it would he much appreciated.
Edit: would not having my fuel pressure regulator installed yet cause this problem?
JCashen is offline
post #2 of 6 Old 02-18-2013, 06:58 AM
blown50
1987 YJ Wrangler
Ok first you do need the pressure regulator as webers hate fuel pressure, I put mine after the filter, so it can return to the tank and not be so hard on the pump. Second is are you sure you are not up on the fast idle cam? Best way I found to get lean best idle was to open the choke plates all the way up, either by letting it heat the choke thermostat or adjusting it off with the thermostat . I'm assuming you have the electric choke. If the throttle is even on the first notch it will uncover the transition port. And you can't get it lean enough to die with the port uncovered. Number three, is the throttle binding someway? I know the hyam joints or the two ball joints whichever you prefer, can and will hang if not in line with each other, so be sure to check linkage for binding. Fourth, no vacuum leak? Check the adapter plates as these are prone to leak at every gasket, I ended up yellow death ing mine as well as using blue locktite on all the bolts. Check all your install, even if you have to start over from scratch. Try all this first then let us know how it works
blown50 is offline
post #3 of 6 Old 02-18-2013, 11:06 AM Thread Starter
JCashen
I just installed the regulator, and the idle mixture screws work now. No tach at the moment so I can't tell my rpm at idle but with a vacuum gauge I'm pulling 21. Linkage also looks good, its smooth throughout the whole throttle position.
Weber turned the plugs black, but after the above they went back to tan. I also put new ones on so we'll see how they work.
On the vacuum leaks I forgot I was out of carb cleaner so I'll have to go get more. What is "yellow deathing"? I read somewhere about putting motor oil on the gaskets, so that is what I did.
JCashen is offline
post #4 of 6 Old 02-18-2013, 11:16 AM
blown50
1987 YJ Wrangler
Yellow death refers to the 3m weatherstrip adhesive I usually use grease, but it didn't work on the weber adapters so I used the 3m, have had no problems since
blown50 is offline
post #5 of 6 Old 02-18-2013, 11:30 AM Thread Starter
JCashen
Is 4psi of fuel to much? None of my local auto stores carry fuel pressure gauges, so I can't get it set exactly until I order one.
JCashen is offline
post #6 of 6 Old 02-18-2013, 12:09 PM
zeus87gn
1987 YJ Wrangler
3.5 psi might work better if you can adjust it that way - that's what mine is set at and runs just fine
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
