4.2 valve cover leak opinions needed - JeepForum.com
post #1 of 14 Old 04-13-2008, 07:06 PM Thread Starter
kaz1961
I search the topic and read through dozens of threads regarding a leaky 4.2 valve cover. My gasket was replaced at a shop by the PO (they charged him $249)! It started leaking a couple of months later and he brought it back to the shop that installed it and they redid it. Well, sure enough it is leaking again. They used a cork gasket with some kind of RTV sealant which some threads say is a no-no and I'm betting they overtightened it to make sure it didnt leak again. At this point I am not sure if I should just try a new gasket (maybe a felpro) or if I should replace the valve cover with a new one. What do you guys think? Is it likely that the cover is warped since it has gone through 3 gaskets in less than a year?
89 Sahara 6 cyl
kaz1961 is offline
post #2 of 14 Old 04-13-2008, 07:28 PM
sam.b.
my gasket leaked like that at the back of hte engine so i had to put some washers on the bolts to make them shorter so i could tighten down a bit more and i havent had the need for any silicone
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #3 of 14 Old 04-13-2008, 10:35 PM
pat8942
pat8942's Avatar
I replaced mine about 4 months ago with a Felpro and torqued it to specs and not a hint of a leak.
You have to torque the bolts a few times in sequence as the gasket compresses but if you do it right it won't leak.
You don't need any RTV Either.
Don't over tighten as that will either crack or warp the cover.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #4 of 14 Old 04-13-2008, 10:46 PM
Douglas S.
If you do end up taking it off, check it on a flat surface to be sure it isn't warped, then reinstall it.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #5 of 14 Old 04-14-2008, 12:11 AM
goatboy
One of the old fashioned way of sealing valve cover/oil pan/timing cover/diff etc gaskets is to use yellow death (3M yellow weatherstrip adhesive) on the cover side of the gasket, and #2 Permatex non-hardening on the other side...I still use this method and rarely, if ever, have a leak...I NEVER use RTV or any other silicone with the exception of where it's recommended in the corners...
goatboy is offline
post #6 of 14 Old 04-14-2008, 01:13 AM
xxxflhrci
xxxflhrci's Avatar
IMO, RTV or silicone is nothing but a mess later on down the road when you need to do it again.
I always use a cork gasket with Permatex Form-A-Gasket 2 on both sides and never have problems getting a good seal.
http://www.shopwiki.com/detail/d=per...pToFirst=true/
xxxflhrci is offline
post #7 of 14 Old 04-14-2008, 06:21 AM
levergun
1979 CJ5
Just remember- if ya fix one leak it's just gonna leak somewhere else. It's a Jeep.
On my 89 YJ I have replaced every single gasket and seal on the engine- and it still oozes out. The joy of having worn rings. The first thing I would do is check the PCV system. It is often the cause of most new gaskets leaking. If it allows pressure to build up it will force oil out everywhere. On my jeep the vacuum line itself- not the valve- was clogged. Pull the valve off with the engine running. It should die almost instantly. If not that means the lines clogged and it needs to be replaced. I personally prefer the Rubber gaskets over cork but that's just personal preference.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #8 of 14 Old 04-14-2008, 01:51 PM
goatboy
Exactly so...the reason for the yellow death on one side is that theoretically, you can pull the cover off and reuse the gasket...can't say that I ever have to do that much, normally, in my experience, once I've replaced that gasket, I personally never have to worry about it again...either it seals like it should, or the vehicle goes down the road before I have to think about replacing it.
goatboy is offline
post #9 of 14 Old 04-14-2008, 02:35 PM
pat8942
pat8942's Avatar
I guess I'm doing something wrong because mine doesn't leak anywhere and I never use RTV,Permatex or Gorilla Snot (Yellow Death).
It can sit for a week and no oil under it.
I guess if yours leaks the it's a Jeep excuse is as good as any.
I have a 74 VW and no leaks on that either.
pat8942 is offline
post #10 of 14 Old 04-14-2008, 06:06 PM
ctm
also you can get a really good gasket at NAPA that has a metal strip sandwiched by cork, sorry I don't have the part number handy.
ctm is offline
post #11 of 14 Old 04-14-2008, 06:10 PM
levergun
1979 CJ5
If you read the whole post.... Mine doesn't leak any more now that I fixed the PCV valve. The first comment was a joke.
levergun is offline
post #12 of 14 Old 04-14-2008, 07:45 PM
pat8942
pat8942's Avatar
Sorry about that, but I read the whole post and you never said you fixed it.
Anyway glad you're leak free
pat8942 is offline
post #13 of 14 Old 04-14-2008, 07:54 PM
goatboy
Excellent! There's a lot to be said about meticulous surface cleaning and preparation...
goatboy is offline
post #14 of 14 Old 05-31-2013, 08:31 AM
kbucket
1987 YJ Wrangler
Fel-pro tech note mentions 4.2L specifically and developed a gasket just for that
http://aftermarket.federalmogul.com/...et%20Facts.pdf
Look just below tech tip. It is the worst leaker ever and AMC tried foru time to fix it and failed. Fel=pro developed Sponge Lam just for this engine.
I'm giving it a shot. The Sponge-lam trademark was released several years ago and this gasket is not on their website. I did find one at NAPA and their computer has it listed as Sponge-Lam type. The Perma-Dry Plus is not offered for the 4.2 which originally came with Plastic Valve Cover (Vin J) but is offered for VIN C, which has several more stud holes.
The Sponge lam gasket I got look like it had been on the shelf for a while and had some curling, so we did permatec 2 non-drying on the bottom and 3m yellow weather strip adhesive on top.
Hope it works, noting has so far, including, cork, rubber, RTV, right stuff. One issue I see is the engine tilt front to rear has oil pooling up on the rear of the cover, basically an oil dam.
We have been meticulous cleaners on each attempt. As Fel-pro say, this engines "defies" solution.
87 YJ Original rebuilt 4.2L Howell EFI, AX15, NP231 w/4Low, 1.5" SOA' D44 double DOM re-tubed Front' Rough Stuff Fabricated 9 inch Rear w/Strange Carrier
Dutchman Axles - Foot Foundry 30 spline front 35 spline rear, ARB both, Master Power Brake Booster with new El Ddorado Style Rear Disc/ Parking Brakes, 35" MTRs
kbucket is offline
oil leak from top of valve cover 89 2.5l Gildedseat YJ Wrangler Technical Forum 5 10-20-2011 03:31 PM
HELP --- Valve cover leak Bruner3 TJ Wrangler Technical Forum 20 07-29-2009 10:50 PM
Oil Leak - new Valve Cover Force10 YJ Wrangler Technical Forum 12 11-16-2007 05:11 PM
Valve Cover Leak LeeGro TJ Wrangler Technical Forum 5 01-20-2007 04:21 PM
4.2L Oil Leak out of valve cover fyristus YJ Wrangler Technical Forum 7 05-19-2003 09:06 PM
