4.2 randomly running bad - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2 randomly running bad
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 05-20-2014, 01:04 PM   #1
kenh
Hey all,
Have a 4.2 with a MC2150 carb I installed a few weeks and stock distributor. For the most part it's been running pretty well, but I've been having issues with a hesitation on acceleration. It didn't happen all the time though, and for a while I thought it maybe only happened once the engine got warm but I don't think that's the case.
Yesterday I decided to change the distributor to use manifold vacuum instead of ported and for the rest of the day it was great, the hesitation was 95% gone, it idled better, accelerated better, etc. I thought my issues were solved.
Today I started it up and it sounded like crap like the timing is off, idled rough, big hesitations on acceleration, and it's been doing this all day when hot and cold, after not changing anything from yesterday when it was running great.
I'm not sure what to look for at this point? ICM? Timing chain? Distributor?
Any help is appreciated, thanks.
'89 Islander - 4.2, MC 2150
kenh is offline   Reply With Quote
Unread 05-20-2014, 01:40 PM   #2
sardog211
Check your timing as you stated, look at your power valve, if it's wet you have under the PV, it's bad, also spray some carb cleaner and check for vacuum leaks. How does it idle? What rpm do you have it idling at? Lastly how do the plugs look?
Have you done the nutter bypass yet?
sardog211 is offline   Reply With Quote
Unread 05-20-2014, 02:02 PM   #3
kenh
Nutter has been done, I'll have to check the power valve, I'm not sure exactly how that's done though.
I don't believe there any vacuum leaks, but wouldn't hurt to spray some cleaner around. It's idling around 900 right now (was 800 with ported vacuum but I haven't adjusted it yet). It's not idling very good right now, but was great yesterday like I said. I also changed the plugs about a week ago which didn't resolve the issue.
Unread 05-20-2014, 04:10 PM   #4
dancytron
You probably need to adjust the vacuum advance. Manifold vacuum is a lot more powerful than ported vacuum, so you can't just switch them. You just need to stick an allen wrench into the place where the tube hooks on. Search, there are threads on how to to it and what allen wrench you need.
dancytron is offline   Reply With Quote
Unread 05-20-2014, 04:51 PM   #5
kenh
Thanks, I'll give that a shot. Does the base timing need to be set with the vacuum hooked up to the distributor when using manifold vacuum, since it's pulling at idle?
Unread 05-20-2014, 06:53 PM   #6
Old4X
1990 CJ7
Set base timing with vac advance un hooked and line plugged.
Set idle speed once you plug the vac line back in.
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
