4.2 problems after stalling in water... - JeepForum.com
post #1 of 2 Old 06-17-2007, 06:13 PM Thread Starter
dbikers
Went wheelin' this weekend. Happened into a deep water hole and the jeep stalled...this isn't the first time this has happened.
After gettin' my 4.2 started again it ran fine, just won't idle worth a @#$%.
Driving on the road is just as it's always been (pretty good for the stock POS carb) with the timing and idle set as per the spec. It used to idle at 700 rpm and purr like a sewing machine. Now at idle it seems to be missing horribly.
So i've checked to make sure all electrical and vacuum lines are hooked up..seems to have everything in order. I checked the wires and cap...
I can't figure it out and don't know exactly where to look.
I got the ok from the war dept to get the weber but i don't want to do anything until i can get the jeep to run like it did before this weekend (if it's even possible)
Any thoughts would be appreciated.
Thanks in advance
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #2 of 2 Old 06-17-2007, 06:19 PM
4.7stroker
Did you take the cap off and dry it and the plug wires off with wd40?
You if you wanted you can save some cash by installing the Motorcraft carb instead of the webber. Same results half the price.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
Water causes stalling? Vertisce JK Wrangler Technical Forum 6 09-05-2009 07:06 AM
YJ 4.2 engine stalling problems HELP PLEASE mark268 YJ Wrangler Technical Forum 4 06-18-2007 10:59 AM
Stalling problems 4wheeler98 TJ Wrangler Technical Forum 6 03-14-2007 11:43 PM
Stalling problems in 88 PhoenixEML YJ Wrangler Technical Forum 32 04-11-2005 02:19 PM
Stalling problems soxfann YJ Wrangler Technical Forum 6 11-20-2004 06:18 PM
