4.2 Nuttered Idle Issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2 Nuttered Idle Issues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 09-15-2014, 09:09 PM   #1
ratat98
My YJ has been sitting for a couple weeks because I've been busy at work, and now when I get it out and drive it, it randomly idles around 500rpm sometimes, and other times around 1000. Before I let it sit, it was idling steady around 700-800ish with no problems. I've searched the threads and can't seem to find the same issue. Anyone have any ideas? Do I just need to clean the carb again?
I don't know why, but I just can't NOT own a jeep...
ratat98 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2014, 09:18 PM   #2
Old4X
1990 CJ7
Run real gasoline, not ethanol laced gas, that cures most idling problems with carbs.
Do you have both return springs on the throttle arm? Are the throttle shafts gunk free? If not, carb cleaner will free then up.
Are your throttle shafts loose in the throttle body? This can make them stick and not return to proper position at idle. They can be re-bushed if worn.
And these engines will develop vacuum leaks if you look at them crosseyed. Check torque on carb baseplate and intake to head bolts. Also look for cracked vacuum lines.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 09-15-2014, 09:23 PM   #3
ratat98
Thanks for all the advice! I didn't even think about ethanol..I'm pretty sure that's it since I just had to replace the carb on my chainsaw, due to what I've been told was, ethanol eating the seals. I've checked for vac leaks and checked the timing.. I'll squirt some carb cleaner on the goods, and let that sink in for a bit then get some octane booster and see if I can even find an ethanol free gas pump in this little town.
Unread 09-15-2014, 09:28 PM   #4
Old4X
1990 CJ7
Around boating areas usually have it. Outboards can't run ethanol fuel.
Unread 09-15-2014, 09:35 PM   #5
mike134
I wouldn't hurt to spray carb cleaner around the vacuum lines to check for vacuum leaks though. It may still be a small intermittant vacuum leak.
mike134 is online now   Reply With Quote Quick reply to this message
Unread 09-15-2014, 10:15 PM   #6
ratat98
With it being nuttered, there really aren't a whole lot of vac lines that I need to check, but I will check them just to be sure. I need to rip a bunch of them out anyways...
Unread 09-15-2014, 11:40 PM   #7
mike134
Doesn't the nutter bypass still have a vacuum line going to the carburetor? If so,then you need to make sure none of the vacuum lines leak, whether they are being used or not. A leak in any vacuum line will reduce manifold vacuum and allow extra air into your engine, both of which can cause problems elsewhere. You can remove the extra lines since they are prone to failure, but you have to plug up the ports that you no longer want to use.
This is a very good diagnostic to do because it is fast and free.
Unread 09-15-2014, 11:53 PM   #8
ratat98
Oh yeah most of mine are plugged already which is why I said that. There are the few left though that it needs. I just forgot how many were left. I miss the old vacuum line free days....
Unread 09-16-2014, 07:22 AM   #9
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
A common issue that causes that is a chunk of dirt in one of the idle pickup tubes. The tubes have crimped ends that were made too small so they trap dirt. The fix is to drill or ream them out to at least .032". The test is to carefully look down the carb at idle and gently give it some throttle. If you see drops of gas instead of mists of gas, you have plugged tubes. Check out the site Jeep adventures under the hood by Dale Beckett for the fix directions. I used welding torch tip files to ream them but small drill bits can be found.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 04:48 PM   #10
ratat98
Okay I've cleaned the carb, and tested the vac lines to no avail.....any other ideas?
Edit: and the carb did have some dirt stuck in it..blowing misty now instead of dripping..didn't help the problem though..
Unread 10-10-2014, 06:52 PM   #11
mike134
A lot of Marathon stations are still ethanol free!
Unread 10-10-2014, 07:21 PM   #12
Old4X
1990 CJ7
Have you done this?
http://www.jeeptech.com/engine/carter.html
Unread 10-10-2014, 07:40 PM   #13
ratat98
I did take the carb out and thoroughly clean it, however I didn't go to the extent of running wire down the tubes to clean them out. I'll have to do this once the rain stops pouring!
Unread 10-11-2014, 06:02 AM   #14
Mike Romain
Started after sitting for a while could indicate the gas filter started plugging up. The crud ethanol carries turns to varnish in a fuel filter if given enough time to evaporate away. Gas filters are cheap anyway and should be changed yearly on a daily driver. Just be sure you put it in level with the return line up top.
I would also crack open the gas cap to see if that fixes things. There is a $2.00 air filter on the gas tank vent that can cause the idle to drop down if plugged with dirt. It puts a vacuum on the gas tank starving the carb for fuel.
Mike
