Quantcast 4.2 jug/ 4.0 head swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2 jug/ 4.0 head swap
Old 06-01-2008, 08:13 AM   #1
eche981
I found some parts for the swap last week . I found it all for 175.00. I need to know what parts i am missing for the swap. This is what i have.
1 4.0 head
1 4.0 valve cover
1 4.0 computer
1 4.0 wiring harness
1 throttle body
1 4.0 intake manifold
1 4.0 exhaust header
1 4.0 fuel rail
11 injectors
and a set of 4.0 push rods.
So the question is what parts do i have left to buy to get this thing running? Also do i need to swap out the cam?
_______
l l_[____],
I—L---{[]ll[]}-
(0)_)(0)_)-(o)_) 88 hardtop 258 (Strong motor) 3 in lift, 1 in body , 32X12.50, webber, nutter, HEI upgarde and needs paint.
eche981 is offline   Reply With Quote
Old 06-01-2008, 01:43 PM   #2
Burnerman
You need to do a google search. You'll find what you need. I think putting the FI on is going to lead to alot more parts. You'll need a fuel pump, for one ,and rig up a CPS. Plus a whole lot more....
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 06-03-2008, 02:14 AM   #3
YJRoller
1987 YJ Wrangler
You will also need to have the water ports welded shut on the 4.0 head. Then have it remilled back to flat. It is an easy 30+ hp mod. But ya gotta do it right.
Do not do this fix
"The first step is to prepare the head for installation. After you've obtained all the parts from the parts list, you will need to perform the following task. In order for the 4.0L head to work on the 4.2L block, I had to fill in a couple of water jackets in the 4.0L head. They are the small triangular water jackets on the same side as the intake. These must be filled because on the 4.2L block these water jackets don't exist. I made a couple of calls and came to the conclusion that the best way to fill these holes is to use a high temp epoxy putty. I bought two tubes of QuikSteel. This is a 500 degree max temp super strength epoxy putty found at most auto parts stores."
Get a head that was professionally done. Like this one
http://cgi.ebay.com/ebaymotors/AMC-JEEP-258-4-0-H-O-Conversion-Cylinder-Head_W0QQcmdZViewItemQQcategoryZ33617QQihZ024QQite mZ370054977227QQrdZ1QQsspagenameZWDVW
Jeep, The name says it all
Just Empty Every Pocket
1987 YJ, 258, Weber 34, Nutter done, Welded and Posilocked D30, , D35 in rear, Killer storage box in bed, custom front hoop, hand throttle,
YJRoller is offline   Reply With Quote
Old 06-03-2008, 08:12 AM   #4
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
Ok, since the subject was brought up, why do these holes have to be filled?
If the water jacket holes don't exist in the 4.2 block, wouldn't the 4.0 head gasket seal them straight to the block? Or the 4.2 gasket seal them off right at the head?
Just looking for opinions and experience here.
Patrick
Holley Carb thread
zeus87gn is offline   Reply With Quote
Old 06-03-2008, 12:22 PM   #5
Douglas S.
1987 YJ Wrangler
i think the holes are too close to the edge to be left unfilled. Also, i don't recommend you weld the holes because it could cause some serious warping and even more milling would be required. When i did this swap i just used j and b weld. I'm very happy with my results
before:
after
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S
1987 YJ Laredo
Douglas S. is offline   Reply With Quote
Old 06-03-2008, 12:32 PM   #6
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
Douglas,
Nice work!
I see your 4.2 intake manifold bolted right to the 4.0l head.
This is what I have planned as well.
Did you hae any problems with the manifold alignment?
Did you get the expected 30-40Hp gain with your carb setup?
I have heard of the JB weld trick and was going to try it.
I will guess you haven't yet experienced any leaks?
How old was your motor (mileage) when you converted?
Z
Patrick
Holley Carb thread
Old 06-03-2008, 12:43 PM   #7
YJRoller
1987 YJ Wrangler
NICE WORK DOUGLAS!!!!
I have the same questions as Zeus. I have ben pondering doing this mod for a long time and this is the first actual person that had doc on doing it.
Please reply back to this
Old 06-03-2008, 12:50 PM   #8
Douglas S.
1987 YJ Wrangler
Originally Posted by zeus87gn View Post
Douglas,
Nice work!
Z
- The manifolds aligned very well for me, but i used the factory tubular headers off the 99 cherokee i pulled the head from
- i don't know exactly what i got, but the jeep is WAY WAY faster, it's almost like night and day
- i have no leaks so far
- i just did the swap a couple weeks ago and there are about 140000 km's on the motor
hope that helps!
only problem is getting a good pcv valve gasket for the 4.0 head, haven't really solved this yet
1987 YJ Laredo
Old 06-03-2008, 01:00 PM   #9
zeus87gn
Why am I here?
zeus87gn's Avatar
1987 YJ Wrangler
hope that helps!
You have the newer model head. I have one of the old 4.0HO heads waiting to be built in my garage. Freshly machined, just bare. I don't think there are many differences. I was more concerned with the intake alignment. But if yours bolted up, mine should too!
The exhaust manifold must change, I know this from looking at the head. The ports are completely different, and the 4.0 exhaust manifold is much better than the 4.2 by far!
140k Km is right at 87k miles. That's a relatively young motor.
I guess the PCV valve is a different OD than the 4.2?
Yes it does help!
Thank you very much for posting!
Do you think you have helped your fuel mileage?
Patrick
Holley Carb thread
Old 06-03-2008, 01:04 PM   #10
Douglas S.
1987 YJ Wrangler
haven't really had a chance to check the mileage but it seems better.
1987 YJ Laredo
Old 07-11-2008, 10:26 AM   #11
eche981
so overall what i am getting is that i can use the existing 4.2 intake manifold on the 4.0 head!! If this is correct, what pushrods do i use the new 4.0 or the old 4.2. Also the 4.0 header will fit with the 4.2 intake?. It is all a little confusing. If i can just swap the head and the exhaust manifold out till i get the rest of the parts for the EFI swap that would be great. Is there anything that i am missing here. I would love to do it ASAP. I have the motor 1/2 tore apart right now. Any help would be great. Thanks in advance......
_______
l l_[____],
I—L---{[]ll[]}-
Old 07-11-2008, 02:54 PM   #12
Douglas S.
1987 YJ Wrangler
I believe i used the 4.2 pushrods, but I'm not sure on that one
I used the original 4.2 intake and 4.0 exhaust and it worked out fine
1987 YJ Laredo
Old 07-11-2008, 03:00 PM   #13
eche981
do i need the special washers that allign the head, or are the head bolts for the 4.2 the same as the new head. i believe that the 4.0 takes a 1/2 head and have been told that the 4.2 original was 7/16.
_______
l l_[____],
I—L---{[]ll[]}-
Old 08-11-2008, 07:20 PM   #14
JJ Jeep
1987 YJ Wrangler
Slightly confusing
I have read the 4.0 head on the 4.2 swap and am now thinking of this setup instead of a V8 (have a soft spot for the old 258's). Sounds like a fantastic increase in HP and response and a fairly easy mod. My question is that it is sort of confusing on which model of 4.0 head works best. Also is the head froom an EFI 4.0 OK or are all 4.0's EFI ? Now I'm thinking that a nice clifford intake and header would really be sweet. I'm just wanting to get the best advice of fitting it all together.
JJ Jeep
JJ Jeep is offline   Reply With Quote
Old 08-11-2008, 10:54 PM   #15
wendell
1987 YJ Wrangler
They sell the heads on ebay welded up and ready to go for the swap.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote
Glock Forum
