4.2 Header with Auto Trans - JeepForum.com
post #1 of 4 Old 11-08-2013, 06:04 PM Thread Starter
Rebel442
I've done some looking around a found a post or two with a couple of pics, and it looks like the shifter bracket can be modified to use a header. I cant find any good pics of what was done to modify it though. Anybody done this a got a good pic of the linkage bracket? Thanks.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #2 of 4 Old 11-08-2013, 07:50 PM
jbolty
jbolty's Avatar
best pic I have. You can see the bracket is cut just to the rear of the header and I flipped the cut off part and welded it so I could bolt it in a different place. Also had to get rid of the stock plastic bushing that holds the end of the shift rod because it was melting.
You can't see it here but I have a pretty strong spring pushing the rod against the brass fitting.
I think I may have had to reposition the bell crank as well
Actually, found a pic with the spring.
jbolty is offline
post #3 of 4 Old 11-08-2013, 07:55 PM
jbolty
jbolty's Avatar
Here's the rest of it. Cut off the collector and welded it on facing front and wrapped the exhust. Borla header
jbolty is offline
post #4 of 4 Old 11-08-2013, 07:55 PM Thread Starter
Rebel442
Thanks for the images, looks pretty straight forward. I'd bet I can make something like that work.
Rebel442 is offline
