-   -   4.2 Header with Auto Trans (http://www.jeepforum.com/forum/f12/4-2-header-auto-trans-1772209/)
Rebel442 11-08-2013 06:04 PM
I've done some looking around a found a post or two with a couple of pics, and it looks like the shifter bracket can be modified to use a header. I cant find any good pics of what was done to modify it though. Anybody done this a got a good pic of the linkage bracket? Thanks.
jbolty 11-08-2013 07:50 PM
best pic I have. You can see the bracket is cut just to the rear of the header and I flipped the cut off part and welded it so I could bolt it in a different place. Also had to get rid of the stock plastic bushing that holds the end of the shift rod because it was melting.
You can't see it here but I have a pretty strong spring pushing the rod against the brass fitting.
I think I may have had to reposition the bell crank as well
http://i3.photobucket.com/albums/y95...x/IMGP0214.jpg
Actually, found a pic with the spring.
http://i3.photobucket.com/albums/y95...x/IMGP0213.jpg
jbolty 11-08-2013 07:55 PM
Here's the rest of it. Cut off the collector and welded it on facing front and wrapped the exhust. Borla header
http://i3.photobucket.com/albums/y95...t/IMGP2237.jpg
Rebel442 11-08-2013 07:55 PM
Thanks for the images, looks pretty straight forward. I'd bet I can make something like that work.
The time now is 12:03 PM.
