4.2 exhaust question - JeepForum.com
post #1 of 10 Old 09-16-2011, 03:21 PM Thread Starter
superj
hey guys, i have a 4.2 head and am thinking of using 99 exhaust manifolds. can i do this? i have searched for about 30 minutes now trying different terms and cannot find a thread saying yes or no.
i have a 4.0 head also but need to get it to ndt to check for cracks before i install. i visual'd it and it looked fine but i don't want to install and find something wrong and not have my vehicle to take the kids to practices and such.
also, still no one makes an adapter to put a carb on that 99+ intake manifold? i got that too
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #2 of 10 Old 09-16-2011, 05:42 PM Thread Starter
superj
you guys think i should post this in the cj section? i had forgotten about how a lot of people on here don't know too much about the 4.2
i know its only been two hours
superj is offline
post #3 of 10 Old 09-16-2011, 06:10 PM
gbeltran
No, it won't work. 4.2 stuff is unique to the 4.2 on the exhaust manifold.
gbeltran is offline
post #4 of 10 Old 09-16-2011, 06:44 PM
mark1305
mark1305's Avatar
This may or may not help, but in a previous career I spent a lot of time analyzing lots of things. So I tend to look for cause and effect relationships.
I bought my first Jeep about a year ago, an 89 YJ with a 4.2L motor. Had to redo the exhaust system. One of the glitches was a broken manifold stud at the rearmost position. Reading up on here and another forum, the 4.2L motors have a reputation (on the YJs) for either cracking the rear part of the exhaust manifold or shearing that bolt. When I started reassembling with fresh gaskets etc., it became obvious that the manifold hole did not match the stud position closely enough.
I elongated the hole in the exhaust manifold by about .10 inch with a die grinder. I also found one other bolt or stud with questionable alignment near the middle of the head and relieved it slightly. I don't expect to have a repeat of the broken stud problem nor a cracked manifold. New gaskets on both manifolds and all ran well with no leaks.
mark1305 is offline
post #5 of 10 Old 09-16-2011, 07:00 PM
gbeltran
Why are you trying to put a carb on the 99 intake? You would have to make your own adapter. If you want to keep the carb with the 4.0 head you can use your current intake. I think you might have to grind the mounting flange in a couple spots but it will work.
gbeltran is offline
post #6 of 10 Old 09-16-2011, 08:05 PM Thread Starter
superj
Bummer on the exhaust manifolds, I was hoping they fit.
On the intake manifold, I got the whole head (well, engine) but no harness but no ecu so while waiting to collect parts, I figured I would move to a better flowing intake.
superj is offline
post #7 of 10 Old 09-16-2011, 10:07 PM
444
The 4.0 intake is designed for dry flow with the injectors at the head. It is not suited at all to mounting a carb on. If you want a good flowing carb intake, but one of the aftermarket 4.2 4bbl intakes.
444 is offline
post #8 of 10 Old 09-17-2011, 04:09 AM Thread Starter
superj
I have lOoked at them and if I could find one for a cost I like, I would buy one. I just have a hard time shelling out 2-300 for an intake
superj is offline
post #9 of 10 Old 09-17-2011, 06:41 AM
wanabejeeper
1987 YJ Wrangler
I'm pretty sure the 4.0 HO head will take the 4.0 throttle body intake which can use a carb.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #10 of 10 Old 09-17-2011, 08:36 AM Thread Starter
superj
I only know one guy on here with a 99+ intake and running a carb. He made the adapter himself
superj is offline
97 2.5 Exhaust Manifold Question - Probably a stupid question. F4ion1 TJ Wrangler Technical Forum 7 07-23-2010 08:13 AM
Exhaust question? IH8ROADZ TJ Wrangler Technical Forum 6 03-23-2008 01:07 AM
exhaust question(NO NOT WHICH ONE IS BETTER!!) MZH29 TJ Wrangler Technical Forum 6 11-29-2005 10:08 PM
Exhaust Question ajpthng03 TJ Wrangler Technical Forum 1 04-28-2003 04:56 PM
exhaust question tuggnutt YJ Wrangler Technical Forum 9 09-12-2002 02:39 PM
