4.2 engine trouble - JeepForum.com
post #1 of 7 Old 01-02-2015, 07:02 PM Thread Starter
daltonfarr69
1987 YJ Wrangler
4.2 engine trouble
Before i start i researched a lot before posting this but can't seem to find an exact match to my problem.
The jeep is a 1987 4.2 with the stock carter carb.
Recently it has been having trouble idling and i know that a bad vacuum line is to blame. But the last few times i have driven the jeep the engine will shut off while Im driving down the road in gear. This happens not at idle but in higher RPMs. When this happens it is as if somebody kills the ignition switch and the engine looses spark. after the engine dies ill try to restart it and the engine will fire up for a split second and die immediately (this happens dozens of times till it finally stays running). After several failed attempts the engine will catch and stay running.
Im pretty sure this is not a fuel pump problem because i can smell the unburnt fuel passing through the engine. I was looking at attempting the Nutter bypass but before i attempted i was going to pick yalls brains first.
Thanks for yalls help
daltonfarr69 is offline
post #2 of 7 Old 01-02-2015, 08:10 PM
Mike Romain
A bad ICM can act like that.
Mike
Mike Romain is offline
post #3 of 7 Old 01-02-2015, 08:18 PM
rshbutch
Had same problem. Replace icm
rshbutch is offline
post #4 of 7 Old 01-02-2015, 08:24 PM
dancytron
ICM (ignition control module) is what was wrong with mine when it did that. Hard to test it because it is intermittent. You got to wait until it fails to test it.
Some people replace it with a chevy type from hei distributor.
dancytron is offline
post #5 of 7 Old 01-02-2015, 09:10 PM Thread Starter
daltonfarr69
1987 YJ Wrangler
cool thanks guys, i think ill go ahead and order a replacement.
post #6 of 7 Old 01-02-2015, 09:12 PM
sardog211
CRT HEI and never use that darn icm ever again
sardog211 is offline
post #7 of 7 Old 01-03-2015, 03:28 AM
roadyrob
1987 YJ Wrangler
it could be a bad icm but when mine did that it was the ignition switch. X2 on the CRT HEI, save the money you would spend on a ICM and get the HEI distributor instead.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
