4.2 engine replacement question. - Page 2 - JeepForum.com
post #16 of 21 Old 06-05-2013, 02:07 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Originally Posted by jr4x4 View Post
so if i pull fan/ water pump i could get engine out without taking off grill? it looks like that could be tight.
Were you planning on pulling the radiator as well? It would give you a few inches and mainly keep it safe.
Randonexplosion is offline
post #17 of 21 Old 06-05-2013, 02:17 PM Thread Starter
jr4x4
yes im going to pull the radiator & fan. if i dont have to pull grill that would be cool. i guess il ffind out and see what kind of space i have. my big concern was if i could leave the tranny in.
jr4x4 is offline
post #18 of 21 Old 06-05-2013, 03:00 PM
tslroper
I just went through this not too terribly long ago with mine. I pulled the motor without the transmission, then used the cherry picker to drop the transmission/transfer case straight down onto a creeper (cherry picker stuck into the jeep and strapped to the transmission through the hole in the trans tunnel. When I put the motor back in I assembled it all together and dropped it in as one piece. It took a little pushing and shoving but everything went in pretty well.
These are the only pics I have, but I'm bolting the bellhousing back to the motor and the torque converter up so it can be dropped in. I would note that the load balancer that I have hooked to the engine was almost useless with the trans and transfer case hanging off of the back of the motor. I ended up using the tow strap (repositioned) to hold everything as I dropped it in.
If I had to do it again, I probably wouldnt change a thing. Everything came out and went back in pretty well. Dropping the trans and transfer case out without the motor in is pretty easy whether you use a tranny jack or the cherry picker like i did.
tslroper is offline
post #19 of 21 Old 06-05-2013, 03:06 PM
rykemc
I pulled the 4.0 out of my 95 with the grill and ac condenser still in. Pull rad, fan/clutch and water pump and you will be able to pull the motor with the grill still in. You may have to turn it to the right or left but it will come out with grill still in .
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #20 of 21 Old 06-05-2013, 04:55 PM
Tarpo
You can pull it without taking the grill off. BUT make sure your lift can lift high enough
88 yj. 95 4.0 4 Brl carb, Msd ignition, offenhouser intake, headers. Ford 8.8 rear end, sun fire seats. About to install a newer ax 15 to replace my tired ba10.
Tarpo is offline
post #21 of 21 Old 06-05-2013, 06:22 PM Thread Starter
jr4x4
how come if you pulled engine & left tranny in the jeep. then how come u didnt just leave tranny in? than drop engine back in and bolt up?
jr4x4 is offline
