4.2 Cylinder Head Overhaul?? - JeepForum.com
post #1 of 11 Old 09-30-2013, 08:08 PM Thread Starter
JeepingShtHpns
My 88' hasn't been messed with in a while and I don't feel like i can rely on him fully yet.
I want to overhaul or rebuild my cylinder head.
When i changed a head gasket about a year ago it was bad in there. But now I have time and some cash to do it and i wanna get it done. However I need some help, I know how to take it a part and put it back.
Is there kits? (I couldn't find any)
What parts do I need? (I know the basic stuff like valves, springs, push rods rocker arms...)
what are good/performance parts I should use?
Upgrades???
Tips/Advice?
Thanks for helping out a fellow jeeper
JeepingShtHpns is offline
post #2 of 11 Old 09-30-2013, 08:53 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by JeepingShtHpns
My 88' hasn't been messed with in a while and I don't feel like i can rely on him fully yet. I want to overhaul or rebuild my cylinder head. When i changed a head gasket about a year ago it was bad in there. But now I have time and some cash to do it and i wanna get it done. However I need some help, I know how to take it a part and put it back. Is there kits? (I couldn't find any) What parts do I need? (I know the basic stuff like valves, springs, push rods rocker arms...) what are good/performance parts I should use? Upgrades??? Tips/Advice? Thanks for helping out a fellow jeeper
I hear of guys running Chevy valves , with a nice comp cams camshaft , lifters and valve springs. I would port the head and run a offenhauser intake with a holly 470 truck advenger. That'll really wake up the 4.2 from what I've read.
To be honest for 4.2 tech info the CJ section is the place to go
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 11 Old 09-30-2013, 09:16 PM
Chrisnvegas
Chrisnvegas's Avatar
Yes...
I ran the Holley 390 cfm. It was purrfect!
I started with @ 500 cfm, but it was a bit much. Had a stumble just off idle that I couldn't get rid of. Plugs were always black and wet.
The 390 combined with a Clifford header and my CJ was one happy camper.
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #4 of 11 Old 09-30-2013, 11:44 PM Thread Starter
JeepingShtHpns
i just bought a new Carter 2bb like 4 months ago, which costed some change so i am going to run that for a while. but i have heard a lot of good stuff about those carbs. i wont to up grade that when i do my intake and exhaust headers. Thanks
post #5 of 11 Old 09-30-2013, 11:46 PM
Tom95YJ
Tom95YJ's Avatar
There is nothing Good about the Carter BBD carb, Which is why everyone with a YJ, and CJ swap them for Webbers, and Motorcraft 2100's, Holleys
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 11 Old 10-01-2013, 03:57 AM
roadyrob
1987 YJ Wrangler
if you look in the exhaust ports you will see a casting ridge, remove it with a die grinder. port match the head to the intake manifold, there are videos on you tube that show how to do it. take about 10 thousands off the head to up the compression, your machine shop should be able to tell you the exact amount.
X2 on changing the intake manifold, I run a offenhauser manifold with a holley 390, great setup.
be sure to change the exhaust, you won't see much of an increase if you keep the stock setup. a header would be nice, but I run the stock manifold and down pipe into a 2 1/2" high flow cat and muffler.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 11 Old 10-01-2013, 01:00 PM
c5wagner
What good have you heard of the stock Carter bbd? I swapped mine out for a motorcraft 2100, nutter bypass, and did a TFI ignition upgrade and I love the power my 4.2l puts out now. I also rebuilt my engine which didn't liven it up as much as I hoped, but the other mods I listed above did the trick
1989 Base YJ TBI 350, 4l60, Np231 SYE/6 pin planetary/Wide chain, D30 ARB, 8.8 ARB 4.56
c5wagner is offline
post #8 of 11 Old 10-01-2013, 01:07 PM
c5wagner
Oh man, I didn't see that you are a fellow californian which means most performance mods you do to the 4.2l are illegal and you won't pass smog unless you know a guy that would fail to notice things
c5wagner is offline
post #9 of 11 Old 10-01-2013, 04:51 PM Thread Starter
JeepingShtHpns
A carb. guy told me it was a good one and some buddies said it gets better gas milage then the others lol even tho he couldn't get it dialed in lol. but i defiantly want to upgrade it when i get the change, working at six flags isn't good with the pay .
I know a few guys too
post #10 of 11 Old 10-01-2013, 06:36 PM
c5wagner
I hear you, but I did my mc 2100 swap for around $65-75: junkyard carb $25, rebuild kit $18, adapter plate $12, and air cleaner $12
c5wagner is offline
post #11 of 11 Old 10-06-2013, 12:40 PM Thread Starter
JeepingShtHpns
Thank guys for all the word of advice and help! I am definitely going to upgrade my Carb. now, i had no idea how much the carter sucks but i guess cause im new to this hahalol And if i need anymore help when i take it apart i"ll be back with more questions.
4.2 , cylinder , engine , help needed , overhaul
