4.2 banging sound - JeepForum.com
post #1 of 1 Old 06-20-2010, 02:41 PM Thread Starter
Zutroy
4.2 banging sound
Well, I changed the motor mounts and tranny mounts last week. When I started it up it ran a little rough, stalling a bit while cold. I figured it ran a little rough before and I was just feeling it more because of the new mounts. So I noticed a bit of a rattle on the highway. After a couple days I started her up and the rattle has become a bang. It will run but just on the verge of stall. I took off the valve cover and all seems good. I dropped the pan and checked all the bearings. Also look good. Noticed the timing chain is a bit loose so I'll check that out, but I don't think that is it. Any ideas? I really don't know very much about diagnosing problems. I just take things apart a see what looks busted.
By the way, Noticed a while back that oil pressure runs around 60 until it gets warm. Then it runs around 40 when I am on the gas but about 5 at idle. ? Don't know if that means anything.
Zutroy is offline
Banging sound when shifting, clutch? eric411420 YJ Wrangler Technical Forum 21 12-15-2009 10:27 PM
Banging Sound at Take Off 1st Gear HanksRide YJ Wrangler Technical Forum 16 05-17-2009 07:08 PM
Knocking/Banging sound capecodtjeep TJ Wrangler Technical Forum 6 02-24-2005 08:18 PM
I found that metal banging sound, now what is it cspann TJ Wrangler Technical Forum 16 02-18-2004 05:58 PM
post trail problem-loud banging sound johnniebravo TJ Wrangler Technical Forum 14 11-13-2002 10:18 PM
