4.2 to 4.0 head and MPI Swap ? - JeepForum.com
post #1 of 2 Old 04-12-2010, 04:21 AM Thread Starter
RookieJeeper01
1987 YJ Wrangler
So I'm 90 % complete with the swap and just have a few issues I'm running down. I have a 87 4.2 lower end with a 93 XJ head, MPI, harness, computer, PDC, flywheel CPS, alternator etc.
1. I have just installed a fuel tank with the correct internal pump. I used my stock harness and just put keyed power to the pump. Is this adequate, or do I have to run through the PDC and a fuel relay?
2. Also on the new xj harness there is a 10 GA? brown wire coming from the grey plug in the harness that is about 8 inches behind the alternator. Does anyone know where this goes?
3. Wiring.........I have all the sensors and sending units pluged in less the VSS and I need to find that and the speedo cable adapter at a bone yard.
Now I have the blue wire from the PDC hooked up to keyed ignition at my solenoid. The big ugly power from the PDC to my battery. What other wires to I have to tie in to my old harness to get going?
RookieJeeper01 is offline
post #2 of 2 Old 04-12-2010, 04:40 PM Thread Starter
RookieJeeper01
1987 YJ Wrangler
Need some help. Anyone?
Head Bolt Torque for 4.0 Head Swap + other ? nfisher50 YJ Wrangler Technical Forum 15 06-04-2016 09:00 AM
4.2 intake on 4.0 head? Head swap problems! grimjeeperyj14 YJ Wrangler Technical Forum 27 03-17-2011 10:53 AM
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Which model of 4.0 head to swap the old 258 head? budello YJ Wrangler Technical Forum 2 03-13-2010 08:35 PM
head gasket, head swap, 4.0 or stroker sailor77 YJ Wrangler Technical Forum 3 02-25-2005 04:06 PM
