4.2 to 4.0 fuel pump question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2 to 4.0 fuel pump question
Rugged Ridge 8500lb Winch w/ Steel Cable $294.99 Shipped OSmittybilt Products at Oconee Off-Road!Building a Bumper?
Unread 05-08-2014, 07:13 PM   #1
Motorhead302
I am swaping my 88 yj to a 4.0 and am useing the e2000 I also am useing fuel lines from a 4.0 yj and original tank I have heard to mount the pump as close as possible to the tank but any guidelines on how far I can be from the tank? If you have done it before did you cut the metal line or mount on the rubber line off the tank?
Motorhead302 is offline   Reply With Quote
Unread 05-08-2014, 08:01 PM   #2
superj
1987 YJ Wrangler
I have a 4.0 block in my 87 yj which was a 4.2 originally. I put a holley electric pump on the fender by the cruise control and driver headlight. People talk bad about doing that but its been there two or three years with no trouble.
Slow ride, take it easy
superj is offline   Reply With Quote
Unread 05-08-2014, 09:11 PM   #3
bpounds
bpounds's Avatar
The farther downstream you go, the more difficult it will be for the pump to prime itself. But once it is pulling fuel, shouldn't be an issue on something as short as a Wrangler. It could be a problem if you ever run out of gas and try to prime on the side of the road.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote
