4.2 to 4.0 engine swap question - JeepForum.com
post #1 of 5 Old 12-05-2010, 11:57 AM Thread Starter
dmack3501
Need some advice!
I just swapped out my 4.2/TF-999/NP231 with a 4.0HO/AW4/NP231 on a 1988 YJ.
I seem to have too much angle on the rear drive shaft (it does connect & spin w/out binding) and the front drive shaft is a little too short as well.
Basically, it seems like the new setup is about 3" longer than the original.
Has anyone ever ran in to this before?
Am I just overlooking something simple?
Any input wuld be greatly appreciated!!!!
DMACK
dmack3501 is offline
post #2 of 5 Old 09-05-2011, 10:31 AM
speedbump94
i have an 88 yj also, what year was the 4.0 that you swapped in. i am trying to do the same thong.
/l ,[____],
|-- -L--[]lllllll[]-
()_)-()_)==O=)_)
speedbump94 is offline
post #3 of 5 Old 09-05-2011, 10:36 AM
cevans87
1992 XJ Cherokee
Do you have a lift kit?
You probably need a sye kit
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #4 of 5 Old 09-05-2011, 10:37 AM
cevans87
1992 XJ Cherokee
Both of you should look at my build thread about the 4.0 and aw4 swap
cevans87 is offline
post #5 of 5 Old 09-05-2011, 02:30 PM
bsakal
I did a similar swap, although I installed an AX15 instead of an AW4. I bought new shafts, it was cheaper than having them made. The front shaft was too short. I installed a SYE in the T/C, and bought a Tom Woods rear shaft from Quadratec.
'88 YJ 4.0 AX15 NP231; '97 ZJ; '69 Charger SE 383; '66 Newport 383
bsakal is offline
4.0 , 4.2 , driveshaft , swap , YJ
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Another engine swap question ZacoWacko YJ Wrangler Technical Forum 21 10-15-2010 05:55 PM
engine swap question shaun2733 YJ Wrangler Technical Forum 3 04-21-2009 01:29 PM
Engine swap Question??? wild_weazel YJ Wrangler Technical Forum 7 08-11-2003 05:57 PM
