4.2 and 4.0 - JeepForum.com
post #1 of 5 Old 05-19-2010, 07:42 PM Thread Starter
88blkyj
4.2 and 4.0
are same cast iron block?
4.2 used different heads and cam there stroked to a 4.2?
My uncle has a header he is giving me that was used on his 4.0
pretty sure it would still bolt on?
88blkyj is offline
post #2 of 5 Old 05-19-2010, 08:08 PM
yellow2kgt
Actually the ports are different on the 4.0 head so the header will not work. Swap in a 4.0 head and it will.
Also, the 4.0 block has a larger bore then the 4.2.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #3 of 5 Old 05-19-2010, 09:00 PM Thread Starter
88blkyj
dangit. That just ruined my day... but was what I was expecting =[
thank you.
88blkyj is offline
post #4 of 5 Old 05-20-2010, 08:36 PM Thread Starter
88blkyj
Is there anyone to make these fit beside swapping heads?
88blkyj is offline
post #5 of 5 Old 05-21-2010, 05:21 AM
dodger889
Buy the ones that fit they are only about $100 for the right ones.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
