4.2 258 makes 'fluttering' noise as I let off throttle?? - JeepForum.com
post #1 of 1 Old 09-29-2012, 02:43 AM Thread Starter
MountainmanPaul
I have a 4.2 258 on an 88 YJ. It's stock with most emissions taken off. I've nuttered it and removed the EGR valve then capped it. It has a Weber 32/36 DGEV. I've played with the timing by ear (have no timing light yet) and adjusted the carburetor quite a few times. As I'm letting off the gas it makes a noise, almost like lifters but not really sure what is going on. I'm sure I don't have the timing right but did change the distributor vacuum to a ported line - it was on manifold vacuum. I'm thinking of changing to a Carter 4057 fuel pump thinking fuel pressure is problem for the Weber. Any ideas or help would be appreciated.
MountainmanPaul is offline
fuel pressure , fuel pump , lifters , timing , weber carburator
Ideas on noise source - light fluttering sound at 70mph cwoodffr JK Wrangler Technical Forum 17 11-24-2015 08:20 AM
fluttering noise through shift boot dirtyjpwrangler JK Wrangler Technical Forum 2 11-08-2009 10:06 PM
Fluttering noise in engine ZeroGravity YJ Wrangler Technical Forum 5 03-11-2009 07:24 PM
engine makes weird noise when at about half throttle help??? ryan509 TJ Wrangler Technical Forum 4 12-02-2008 08:06 PM
While Driving - RMPs drop to 1k (fluttering noise) Jutboy YJ Wrangler Technical Forum 6 03-07-2008 07:06 PM
