4.2 258 chain tensioner? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2 258 chain tensioner?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 08-31-2015, 01:03 AM   #1
AC_Spiderman
What is needed for a 4.2 258 timing chain replacement?
most reference I can find says spring tension on 2.5, Snubber on 4.0 and ??? on the 4.2 . If I need the Snubber then I need a new cover as my loose NYLON toothed timing ground the tabs for a non existent snubber. If not then Cloyes Steel timing set, Seal and Felpro gasket set and I am re assembleramma.
AC_Spiderman is offline   Reply With Quote Quick reply to this message
Unread 08-31-2015, 07:09 AM   #2
Jeepsr4me
I just read the FSM and did not see a tensioner at all for the 4.2......
Tip though.. When you put the cover back on, it has a little bit of adjustment left and right, so put it on and loosely bolt it up an Then take the pulley and put it on the crank shaft. This way the seal has equal pressure all the way around the pulley. Then tighten the bolts. If you have to pull the pulley off to get at the rest of bolts.. Just stick it on enough to engage the seal so you can pull back off by hand
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 08-31-2015, 09:49 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
No tensioner. X2 on setting the crank pulley in place to center the seal. Once the cover bolts that you can get to are tight, you take the pulley back off to get the ones under it.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
