4:10 gears???? - JeepForum.com
post #1 of 3 Old 05-09-2002, 07:43 AM Thread Starter
Gper4life
4:10 gears????
I have a set of 4:10's and I want to run 33's. I have the 4.2 in my wrangler and was wondering if I could turn them with ease or not. I noticed in a four banger that the rpm's are about 1000 more than mine in fifth gear. I know that the four banger has 4:10s and I have 3:07s but I put a 4:10 in my jeep for the week one time and it put the rpms around the same range as the four cyl. So would anyone do that or would you do the engine work before you put the tires on or would you go ahead and do the gears and tires. Thanks for any input.
89 YJ upgraded with 95 Chevy LT1 small block, NV4500 5spd, tera low 231 SYE, Custom built crossmembers and skids, 2003 Corvette Electron Blue paint, 3 inch custom spring lift with 2 inch shackles, 2 inch body lift, locked 8.8 with discs, 4:10's and 35's, spray lined tub, and a few other unmentionables
Gper4life is offline
post #2 of 3 Old 05-09-2002, 11:53 AM
93 Blue Demon YJ
Well, I am waiting to regear myself, but I can tell you that going from 3.07's to 4.10's is going to be a big jump, and you will have much more low end power, and running 33's should be much easier.
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #3 of 3 Old 05-09-2002, 07:53 PM
Sublime
I'm not sure what it would be like with 3.07's but 4.10's with 33's is no party. I would think 3.07's would be horrible.
I'm new to the 4.2 and know that it is torquey, but mine has a weber, MSD but the stock exhaust, and 75 mph is about it. That's correcting for the speedo being 10% off.
Around town it's fine and I can keep up and sometimes pull away from traffic, but the E-way in a head wind give it up.
I guess "at ease" is relative.
4" suspension and 3" body lifts with 33's looks pretty damn good.
87 Wrangler-4.2-Peujunk-Weber-MSD-4"suspension-3"body-4.10's-33/12.5/16 Radial Swampers-T-case relocator-RX7 seats.
84 Grand National Stock ;-)!!
Sublime is offline
Yukon 4.88 gears on back order, what gears would be just as good? N2SPD TJ Wrangler Technical Forum 20 02-06-2011 09:19 PM
Jk Rubicon 4:10 gears vs. 1974 Chevy 4:10 gears (pics) Xtremjeepn JK Wrangler Technical Forum 15 12-03-2009 10:09 PM
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 07:34 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 10:55 AM
Will a differnece be noticed from 3.07 gears and 33" tires to 3.73 gears chaznad TJ Wrangler Technical Forum 9 08-26-2005 11:54 AM
