4.0l xj 97 motor into yj 87 - Page 12 - JeepForum.com
post #166 of 252 Old 10-15-2013, 04:44 PM Thread Starter
lbsickboy
1986 YJ Wrangler
I get what you mean about the Black on the yj nss but im talking about the the 2 wires that come of the yj bulkhead that need to be hooked up to the xj transmission nss.
The Brown from the yj for the back up lights Goes to the Brown/light green on the NSS xj
Then the yellow from the yj bulkhead Goes to power on the igntion.
But i want to know where can i splice the wires from the bulk into the nss on the xj but not at the nss it self but at the transmission computer.
Hence the shortes route so i dont have to bring the wires all the way down to the nss at the transmission.
WANGLER 87 4.0 HO AW4
4,5 " ROUGH COUNTRY LIFT KIT, 1.5" BOOMERANG SHACKLES, 33'' BANDEN, ROUGH COUNTRY DUAL STEERING STABILIZER
lbsickboy is offline
post #167 of 252 Old 10-15-2013, 05:47 PM
SLO_Ken
Oh... this whole time, I was thinking you had bolted the 4.0 up to the tf999. I didn't realize you had swapped in the AW4 from the XJ as well
Here's a good step by step article showing how to remove and clean the NSS on your AW4. http://www.bc4x4.com/tech/2010/jeep-...ty-switch-nss/
They call it the "transmission range sensor" in the FSM, since it also tells the transmission control module (TCM) what gear is selected. Here is a diagram from the FSM showing the NSS, and where the wires go.
SLO_Ken is offline
post #168 of 252 Old 10-16-2013, 07:34 AM Thread Starter
lbsickboy
1986 YJ Wrangler
LOL I thought you new i had transfered the hole mick mac motor and tranny
oh it might be i didnt mention it any way now we got that cleared up,
i know that link bean there a few times but it doesn't help me out.
back to the wires brown from the yj bulkhead goes to the brown/light green on the c100 or not the reason i ask is i do have that wire on the xj harness.
but what about the yellow wire from the bulkhead?
i just fried a turn bu fuse when i connected the yellow wire to the battery lol
post #169 of 252 Old 10-16-2013, 10:49 AM
SLO_Ken
You mentioned it, back on post 1. since I didn't jump into this conversation until later, I missed that detail...
The diagram above shows the flow of power through the TRS. You will see that there are two wires that provide power (from the top of the page), and five different outputs, depending on what gear is selected. For the switched/fused power input on the left, you should connect the yellow wire (C6) from the YJ bulkhead to the white wire (A9) on the XJ C100. Then the brown wire (G6) from the YJ bulkhead should get spliced into the brn/lg wire (position 18) at the transmission computer.
SLO_Ken is offline
post #170 of 252 Old 10-16-2013, 11:21 AM Thread Starter
lbsickboy
1986 YJ Wrangler
OK im going to try that tonight ill keep you and all updated.
just what to know if you have done this swap and if yes i started a new thread about the fuel gauge, check my signature please may be you could shed some light on that to
post #171 of 252 Old 10-16-2013, 01:46 PM Thread Starter
lbsickboy
1986 YJ Wrangler
Good news it bloody works i went the way you Sad SLO, but instead of connecting it up at the tcm,
i thought what the hell ill try the Brown/light green wire A15 on the C100 along with the White at A9 and they worked just darn right dandy
Thank you very very very much.
Ps. would you be a gold fellow and send me your adress via pm so i can send you a little somthing.
post #172 of 252 Old 10-16-2013, 01:53 PM
SLO_Ken
Good job!! I missed that the L10 circuit branches off to A15 on C100 in addition to pos 18 on the TCM.
SLO_Ken is offline
post #173 of 252 Old 10-16-2013, 02:01 PM Thread Starter
lbsickboy
1986 YJ Wrangler
If i was to have a choice over the obd2 and the obd1 i would go for obd2
Everything that is needed is on the C100 connector.
Once again Thank you, pm me your adress please
post #174 of 252 Old 10-16-2013, 04:22 PM Thread Starter
lbsickboy
1986 YJ Wrangler
ok just in case some one needs help on the fuel gauge here is the guage you can get that works with the tj xj fuel sender 220-20 ohms full / empty, OBD2 system
http://www.speedhut.com/gauge/G-90-F...90%C2%B0-Sweep)
post #175 of 252 Old 10-16-2013, 05:29 PM
Que89YJ
That other one you listed in the thread would have worked fine as well.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #176 of 252 Old 10-17-2013, 02:34 AM Thread Starter
lbsickboy
1986 YJ Wrangler
ok but i want it to accurate just like factory set up.
just for all that tune in to this thread bear in mind i have not used the xj fule tank nor did i use the xj fuel sender, i have a jeep tj 98 fuel tank and pomp.
fuel pomps are the same on the xj as so on the tj but the fuel sender unit will read different.
XJ 270 ohms empty 20 ohms full +/-5%
TJ 220 ohms empty 20 ohms full +/-5% ( this is my set up)
post #177 of 252 Old 10-17-2013, 01:07 PM Thread Starter
lbsickboy
1986 YJ Wrangler
So today Que89YJ had informed me that fuel gauge with 240-33 ohms is the way to go so that saved me a few $$.
this is the one i have ordered,
http://www.egauges.com/vdo_ind.asp?T...ion&PN=301-105
Also i ordered a new cold air filter
post #178 of 252 Old 10-18-2013, 11:15 AM Thread Starter
lbsickboy
1986 YJ Wrangler
Hi i have a little problem,
i was out testing the jeep, i pulled up along side a truck at the stop lights, the road a head changes from a dubble lanes to a single lane so i thought ill put my foot down so i could get in front of the dam truck,
and guess what my jeep hesitated and i ended up pulling back behind the truck
any way i thought what the hell it might just be a one off thing.
after this had happened the jeep was hesitating when i take corners and when i was driving in a straight line again all was well no problem.
any one got a few ideas what it could be?
also i noticed when i go to start the car, sometimes it will start right up and then 2 or 3 seconds it would cut out on me then would start it again and it would do it again.
then i would start it again it would start no problem
warm or cold it will do it.
post #179 of 252 Old 10-18-2013, 11:53 AM
SLO_Ken
The first things that come to mind are the crank position sensor (CPS), and the immobilizer. The second part, about it dying 2-3 seconds after startup definitely sounds like the immobilizer.
SLO_Ken is offline
post #180 of 252 Old 10-18-2013, 12:10 PM
Que89YJ
I am thinking o2 but don't guess. Do the diagnosis
Fault codes:
No Start:
