4.0l xj 97 motor into yj 87 - JeepForum.com
post #1 of 252 Old 08-27-2013, 10:14 AM Thread Starter
lbsickboy
1986 YJ Wrangler
Hi all
i would like to pick your brains lol,
well not so long a go i had got my hands on a cheap Cherokee xj, i ve bean real busy pulling the block out and transferring that 4.0l to the yj.
I had also decided to go with the AW4 transmission out of the xj.
also decided to stick with the NP231 transfer case from the yj. and got my hands on a SYE KIT .
Everything has gone well up to now, the only thing that's holding me back is the wiring from the jeep xj RHD 1997,
i found this circuit pinout diagram for the Cherokee xj all the wires are numbered in circuit and not function, so that didn't not help much
http://www.jeep4x4center.com/jeep-se...ar=0#toolbar=0
i need to use the yj bulkhead connector and try to splice the xj pinout connector into yj.
Ive already cleand up the wiring loom from the yj that's all labeled and ready to go, i used this wiring diagram,
http://i63.photobucket.com/albums/h1...0/461960d8.jpg
now i just cant find the write diagram so i can connect it the jeep yj bulkhead.
who can help me out here
lbsickboy is offline
post #2 of 252 Old 08-27-2013, 12:38 PM
Que89YJ
I went digging and I dont have one. If you had a real sevice manual you could search the pdf for the circuit on the pins. I will look when I get home to see if I can find one. The Morris online is definitely not searchable using adobe.
Que89YJ is offline
post #3 of 252 Old 08-27-2013, 12:56 PM
superj
find that one we linked up last week or the week before, search for fsm or 87 fsm. we just linked it again so its good.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 252 Old 08-27-2013, 01:02 PM Thread Starter
lbsickboy
1986 YJ Wrangler
ok thanks,
all i want to do is play with my jeep.
post #5 of 252 Old 08-27-2013, 02:18 PM Thread Starter
lbsickboy
1986 YJ Wrangler
thanks for you input but im not looking for the yj diagrams with function ive got all that done and ready,
im need to know which wires i need to use from the above pinout for the cherokee xj 1997 so i can match them up with the yj 87
post #6 of 252 Old 08-27-2013, 02:23 PM
94chb
when i did my swap, i just looked up the pin out for the donor then matched it up myself, sounds like you need to swing over to the xj page and ask or search there for a pinout.
i stayed obd1 , your wiring a obd2 system in a obd1 jeep. so your gonna have some fun.
94chb is offline
post #7 of 252 Old 08-27-2013, 02:26 PM
Que89YJ
I will look when I get home in hour. You need to make s sure it's a 97. There is a huge difference between the 96. The obd 2 was on the 97. You can tell by the engine computer for sure.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 252 Old 08-27-2013, 02:30 PM
Que89YJ
You beat me to it 94! The production in Europe lagged the us so he might have a 96. A ECU pic would help to make sure. The 96 through 98 had many rolling changes.
Fault codes:
No Start:
Que89YJ is offline
post #9 of 252 Old 08-27-2013, 02:33 PM Thread Starter
lbsickboy
1986 YJ Wrangler
ive know there is some one on the forum who has done it i just cant find them.
post #10 of 252 Old 08-27-2013, 02:37 PM
Que89YJ
Yes they have. Obd 2 is more difficult. Let me see what I can Find
Fault codes:
No Start:
Que89YJ is offline
post #11 of 252 Old 08-27-2013, 02:42 PM Thread Starter
lbsickboy
1986 YJ Wrangler
Thanks ill keep tuned in
post #12 of 252 Old 08-27-2013, 02:42 PM
94chb
96 is also obd2 , 96 is the odd ball year, they used obd2 system but in a older style body jeep, ive had a 96.
i would suggest just going to scrap yard and grabbing obd1 harness sensors, and ecu . form the looks its alot of work to run obd2, since the obd1 system is 7 volt and the obd2 is 5 volt system, you gotta run o2 sensors, and the wiring on the aw4 trans . ive googled and havent found any real good DIY
94chb is offline
post #13 of 252 Old 08-27-2013, 05:21 PM
Que89YJ
I looked and I have manuals for everything chalet 2002 up to 05. I can take a look around work tomorrow.
Fault codes:
No Start:
Que89YJ is offline
post #14 of 252 Old 08-28-2013, 10:37 AM
Que89YJ
Sorry, I looked and didnt have any luck. Try posting to the XJ forum and see if anyone has a PDF copy so you can search it or a different pinout of it.
Que89YJ is offline
post #15 of 252 Old 08-28-2013, 12:56 PM Thread Starter
lbsickboy
1986 YJ Wrangler
ok thanks would you do me a favor,take a picture of your set up at the fire wall.
i might just be able to get it that way,with a fsm.
