4.0L Water Plug removal. . . - JeepForum.com
post #1 of 4 Old 05-25-2013, 05:42 PM Thread Starter
atomicjoe23
What do you use to remove the water plug on the driver's side of the block on a 4.0L engine?
It's bigger than a 1/4", but it's smaller than 3/8". . .at least I can't get a 3/8" socket drive into the recess.
Want to remove it to install a temp. sensor there for an electric fan conversion.
Thanks!
'94 Jeep YJ Wrangler
4.0L I-6/AX-15 5-spd./NP231 2" Body Lift
'49 Jeep Willy's Truck
350SBC/TH350/NP205, 14-bolt rear/D60 front
40" BFG MTR's on H2 8-lugs
atomicjoe23 is offline
post #2 of 4 Old 05-25-2013, 06:27 PM
jsawduste
2006 YJ Wrangler
It is 5/16th`s. Waste a 3/8fh`s by grinding it down.
jsawduste is offline
post #3 of 4 Old 05-26-2013, 01:24 PM Thread Starter
atomicjoe23
Thanks jsawduste. . .
. . .weird that it would be an unusual size like that for a square drive. I looked online on Craftsman, and at all the local parts store for a socket attachment that would fit with no luck. . .appreciate you cluing me in.
post #4 of 4 Old 05-30-2013, 08:34 PM Thread Starter
atomicjoe23
A modified socket extension isn't the best solution as it turns out. . .snapped right off where the detent ball is located.
Gonna make a custom tool to remove the water plug out of some 1/2" 4340 hex stock and mill a 5/16" square on the end of that. . .will be able to drive the tool with a 1/2" hex socket with the ratchet wrench this way. . .too bad I will only need to use it once.
