4.0l vs. 4.0l HO - JeepForum.com
post #1 of 12 Old 09-10-2009, 01:43 PM Thread Starter
cgracing
4.0l vs. 4.0l HO
Is there a difference between the 4.0l and the 4.0l HO? If there is a difference what is it and how do you identify it from serial numbers casting?
cgracing is offline
post #2 of 12 Old 09-10-2009, 01:59 PM
Louie4
The only differences I've seen is the wiring but I'm sure there's more to it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 12 Old 09-10-2009, 02:06 PM
sprowley
There's a fair bit of difference actually.
But first, no YJ has a non-HO 4.0L engine, really only Cherokees from 87-90
the non-HO has a different head and different fuel injection system often referred to as the Renix system. The head is a bit more restrictive and the injection wasn't multiport. After Chrysler bought AMC in 88 they redid the 4.0, gave it the PowerTech HO (High Output) designation and slapped it in Wranglers in place of the carbureted 4.2Ls.
There's a difference of like 15 or 20 ft-lbs and hp between the two versions.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #4 of 12 Old 09-11-2009, 02:31 AM Thread Starter
cgracing
OK, I checked it out yesterday. Visually it looks the same with the exception of a/c and a few other minor things. Stamped on the side of the block is I05MXI4 which if I translated correctly would mean-
  • "I" is really a 1 meaning 1991
  • "05" means it was built in May
  • "MX is 4.0L
  • "I4" is really 14 meaning built on the 14th day of the month
Am I correct? If so, this should be a direct bolt in with the same spec cam and injectors as my 1991 YJ 4.0L
Also, There is an automatic transmission included with the sale. Which autos came in these Cherokees?
cgracing is offline
post #5 of 12 Old 09-11-2009, 08:24 AM
sprowley
Someone correct me if I'm wrong but any 4.0L from a Wrangler should/will directly bolt into another Wrangler with no differences.
And 91 is when the HO version started so yeah it should be the same specs as any other wrangler 4.0L
sprowley is offline
post #6 of 12 Old 09-11-2009, 01:37 PM Thread Starter
cgracing
I thought I specified earlier, but I didn't. This motor came from a cherokee, the year is unknown.
cgracing is offline
post #7 of 12 Old 09-11-2009, 01:41 PM
sprowley
Oh, well in any case it will bolt up the same. 4.2 and 4.0 of any stripe I think bolt in the same. And as long as you have a complete engine with the harness and computer and stuff... it should just work.
sprowley is offline
post #8 of 12 Old 09-12-2009, 05:40 AM Thread Starter
cgracing
Thanks for the help! The noob appreciates it.
cgracing is offline
post #9 of 12 Old 09-12-2009, 12:24 PM
Krochus
Actually the renix injected 4.0's are a MPFI setup FWIW
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #10 of 12 Old 09-12-2009, 12:41 PM
sprowley
My bad, sorry! I thought it wasn't. I got the rest right though, yes? I wasn't quite sure about the years but I didn't think the 86 Cherokees had it as an option. Comanches had the Renix 4.0L too, I think.
sprowley is offline
post #11 of 12 Old 09-12-2009, 04:50 PM
Krochus
Honestly I only commented on the part I knew. But I need to find out what the mechanical diffrences are as I'm holding onto a couple good running remix 4.0's on the assumption that the long block can be used as a spare for the rigs in my signature.
Krochus is offline
post #12 of 12 Old 09-12-2009, 05:08 PM
USMC_XJ
2003 WJ
Any 4.0 from a Cherokee from 91-99 will be a direct bolt in for your 92 YJ. The 4.0's were the same. I only say to 99 because in the 00-01 years, the intake and the ignition was redesigned to a distributor less ignition and the intake was made differently for a better flow. The AX-15 you have was also put behind these from 91-01. So it should be a direct swap.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
