4.0L cylinder head mod - JeepForum.com
post #1 of 6 Old 02-25-2009, 02:58 PM Thread Starter
rocklee
im going to have my cylinder head off of my 4.0L, no reason to list why cause that not the point of this thread. does anyone have suggestions for performance mods to do to the cylinder head while its off?
its kind of hard to search for because all you end up getting is thread of people putting 4.0 heads on 4.2's
rocklee is offline
post #2 of 6 Old 02-25-2009, 04:24 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
You could port and polish it. Just Google up port and polish a cylinder head. It is a marginal improvement in some heads. for other heads it is a great improvement. The 4.0 head already flows decent but there is always room for improvement.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 6 Old 02-25-2009, 05:49 PM
shaggyjim
Ya a gasket match, polish and clean up the bowls. Maby get some oversize valves and roller rockers if money is not a big thing.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #4 of 6 Old 02-25-2009, 05:57 PM
jeepdude1987
1987 YJ Wrangler
on the 4.0 your not going to gain anything by port and polish cause your power is being used at low revs. acutally you can make power worse on engines like this with a port and polish. Roller rockers and other such things can help.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
post #5 of 6 Old 02-25-2009, 06:06 PM
Jeeples
Jeeples's Avatar
Get rid of it and buy this:
http://www.hesco.us/shop.asp?action=...115&catId=7735
Hope you got a healthy tax return this year
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 6 Old 02-25-2009, 06:45 PM Thread Starter
rocklee
lol at that point i would just get a later model v8 to throw in. it looks like VERY mild porting and a polish is what ill do.
rocklee is offline
cylinder head help vball12 YJ Wrangler Technical Forum 7 01-19-2010 08:14 PM
Will a 4.0 cylinder head from an '03 work? Ironman23 YJ Wrangler Technical Forum 0 07-13-2008 08:39 PM
New cylinder head? JeSimmers TJ Wrangler Technical Forum 0 06-22-2008 10:23 AM
Cylinder Head ? JeepJinx TJ Wrangler Technical Forum 8 01-29-2008 07:35 AM
Where to buy rebuilt cylinder head? Tshark299 YJ Wrangler Technical Forum 4 07-09-2007 04:47 PM
