4.0L cranks but no start, no roll start - JeepForum.com
post #1 of 12 Old 04-09-2009, 09:47 PM Thread Starter
flame0086
So a couple of days ago, the jeep would take longer and longer to start. When it did start, it would run fine; no idle problems, no loss of power. Now it won't start at all. I've even tried roll starting it three times.
I used my hand held volt meter and read 12.42V on the batter, although the meter in the cab is in the red. The starter cranks like normal, and I can smell gas from the tail pipe. The fuel pump was replaced about three weeks ago and is under warranty. I popped off the coil, reads 1.2 ohms across the two small plugs, and 11K ohms from the distributor plug to one of the small plugs (hope that makes sense).
Engine codes are 12 (battery disconnected last 50 key on), 15 (no vehicle distance/speed sensor signal) and 33 (no A/C).
If anything, tomorrow I'll remove the starter and get it tested. Like I said before, when it ran before, it ran perfectly. Thanks in advance.
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #2 of 12 Old 04-09-2009, 10:15 PM
KyleS
If its cranking like normal don't hastle with pulling the starter. It could be a number of things causing it but with 4.0L the number one cause of the engine just dieing or not starting is the crank position sensor, followed by the cam position sensor. I'd start with the crank sensor its cheap and easy to do.
KyleS is offline
post #3 of 12 Old 04-09-2009, 10:32 PM
estinson
I just replaced my crank sensor... I was having starting problems where it would crank, but not start... I found a trick where if you slammed the skinny to the floor while starting it would start!
with the new crank sensor it starts just fine like before!
estinson is offline
post #4 of 12 Old 04-09-2009, 10:56 PM Thread Starter
flame0086
A failing CPS is usually an intermittent issues. It also causes the ignition to quit even while driving, therefore it should have given me issues while driving and not just starting. Plus it did not throw a CPS error code. If there is a way to check the CPS, please let me know.
Get Lost
post #5 of 12 Old 04-10-2009, 11:07 AM
estinson
hmm... well my CPS issue never caused any problems while driving. It just had a terrible time starting, once started it drove great.
estinson is offline
post #6 of 12 Old 04-10-2009, 06:15 PM Thread Starter
flame0086
Well, I just replaced the CPS. I cracked the plastic shell inspecting it. However, still the same issue. The jeep does not start at all.
Get Lost
post #7 of 12 Old 04-10-2009, 07:14 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Don't remove the battery or starter they seem to be working fine. How is the spark at the plugs? A weak, or no spark could be your problem. That could be related to your rotor, cap or coil/module. Low fuel pressure or a clogged fuel filter could also cause your troubles.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 12 Old 04-10-2009, 09:48 PM Thread Starter
flame0086
I just replaced the wires and it seemed to work. I started it five times in a row, drove to the dry cleaner, then to the store. Then it decided it didn't want to start again. Popped the hood, made sure all the wires were tight and cranked again. Eventually it started. Once its running, no problem.
The engine was replace about 10K miles ago. I checked the distributor and it was fine. You can smell the gas when its cranking. Sometimes it will try to start (more than just the starter turning), but it just wont take off. It makes me think that there is no spark or a weak one. But I can't figure anything out.
I replaced the fuel filter about a year ago, and the pump was done 3 weeks ago. The pump is under warranty, and they gave me a 1-800 number since the shop is 400 miles away.
Get Lost
post #9 of 12 Old 04-10-2009, 10:55 PM
estinson
Sorry man, I tried to start mine today and it's back to what it was doing too... It only starts if you jam the gas to the floor. Once started it seems to run fine.
estinson is offline
post #10 of 12 Old 04-10-2009, 11:03 PM Thread Starter
flame0086
Yea, I've jammed the skinny to the floor hoping that the fuel/air mix is mess up, but no such luck for me.
I'm going to try to mess with it more this weekend, get some more opinions from co-workers. If its still not right monday, its going to a shop that the fuel pump warranty is under.
Seems like you and I have a similar problem. I'll keep this thread posted, especially when its fixed.
Get Lost
post #11 of 12 Old 04-10-2009, 11:03 PM
PhilipSandgren
Ok, ill start with the basics, have you tried the srcew driver in the spard plug wire, to see if you have a constant spark? What about spraying starter fluid in the air intake while trying to start it? these steps can tell you if it is either fuel or spark caused,
hope that was help, i dont really know were you are in the problem solving steps
PhilipSandgren is offline
post #12 of 12 Old 06-15-2009, 06:00 PM
BadApple1403
mine will do this sumtimes and its not uncommon for wires to become loose in the fuse box try checking your relays for corrosion and try bumping ur fuse box....if your jeep starts after u hold the pedal to the floor its because it is becoming flooded while cranking and when the pedal is pressed it goes in to a deflood mode..thank god for an uncle whos a 5 star mechanic
BadApple1403 is offline
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 04:44 PM
89 Yj Cranks but won't start 19yj89 YJ Wrangler Technical Forum 8 10-12-2009 04:32 PM
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 08:16 PM
2.5L cranks but no start. Ptr YJ Wrangler Technical Forum 2 07-12-2009 10:48 PM
My Jeep Cranks And Cranks But No Start!!! b1ack2tar YJ Wrangler Technical Forum 5 01-14-2009 09:23 AM
