4.0L buildup help - JeepForum.com
post #1 of 6 Old 11-29-2006, 01:21 AM Thread Starter
Midnight22
4.0L buildup help
I have a 4.0L out of a 92 wrangler, owner said it was a High Output... got all the wiring and goodies to go with...
i want to run a NV3550 mated with an atlas II either 3.0 or 3.8... so i cant go above 300hp because of the tranny... i'll be happy with 250-270 hp... anymore and i'll have more tickets than i'll want to think about... now heres the question...
what can i do to the engine to get there? internally and externally... i already have a stage 2 clutch from clutchmasters or something... and im gonna get a high flow exhaust and hi-flow CAT, any other recommendations? dont wanna spend a lot, but i dont wanna skimp either...
Nate
Midnight22 is offline
post #2 of 6 Old 11-29-2006, 07:18 AM
GrimJeeper91
GrimJeeper91's Avatar
If you are planning on that much horse power from a 4.0 I'm assuming you will either be stroking it or adding a super charger.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #3 of 6 Old 11-29-2006, 10:21 AM
myjeepsux420
http://www.jpmagazine.com/techarticl...troker_engine/
This will give you an idea of what output you can get from a stroker.
http://www.avengersuperchargers.com/
These guys say they have a 400 hp 4.7L I-6 with a supercharger
1995 YJ Stroked 4.5L I-6 Headders, high flow cat. and exhaust Big Bore Throttle Body, Cold Air intake
Jet Chip Stage 2 plus thermostat
3 1/2 inch lift with 33x12.50 tires
Posi Lock front diff and Ford 8.8
myjeepsux420 is offline
post #4 of 6 Old 11-29-2006, 04:33 PM Thread Starter
Midnight22
oh wow, whats the stock horsepower for a 92 HO? i guess it would help to have a base hp... 200 or something? i looked at the golen website, and it takes a stroker to hit 260... i figured a mild build plan, use 4.2 rods or something (is there a write up for that?) and it would increase a lil, and add a 62mm throttle body with spacer and a short ram intake along with headers and exhaust... and it would go up 50 hp... guess i'm more than a lil wrong... any threads or websites that would have a lil more detailed instruction? i saw one once that listed various strokers and the gains from it... also know of a couple threads detailing various installs that helped hp...
N
post #5 of 6 Old 11-29-2006, 04:46 PM
90yjkrawler
Its going to take a lot of shop work and money to get it in the 300 HP range. All the built strokers (4.7L) I've read about had performance exhaust and intake with larger throttle bodies still didn't put 300 HP to the ground or the flywheel. If you bore and stroke to a 5.0L you'll be close but should prolly sleeve the cylinders. With a supercharger Avenger says they have got a blown 4.7L stoker to put out 400HP, but the site is under construction right now so there's no wirte up or Dyno charts.
Until They All Come Home!
90yjkrawler is offline
post #6 of 6 Old 11-29-2006, 09:19 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
N
http://www.angelfire.com/my/fan/stroker.html
http://www.jeep4.0performance.4mg.com/stroker.html
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
1 ton TJ Buildup tweba99 TJ Wrangler Technical Forum 166 06-09-2009 02:37 PM
Help! Icy buildup on AC unit wbgordon TJ Wrangler Technical Forum 10 03-19-2009 01:37 AM
F8.8 Buildup for TJ Spectre66 TJ Wrangler Technical Forum 15 03-01-2007 11:29 AM
Buildup for my '04X Lud04X TJ Wrangler Technical Forum 7 08-29-2006 06:22 PM
My first TJ buildup - Need help! Trailmaster TJ Wrangler Technical Forum 8 03-16-2004 06:08 AM
