4.0 without air belt config? - JeepForum.com
post #1 of 5 Old 02-20-2012, 01:44 PM Thread Starter
GunNut1
I swapped a cherokee 4.0 into my yj. I have already swapped in a centered yj/tj water pump. I changed over to a YJ style power steering pump. I am still running it with the cherokee AC pump in place, but it is not hooked to anything. I already have on board air, so I just want to eliminate the AC pump. I bought a non AC belt. I cannot get the belt config correct. Do the non-AC YJs use a differeent alternator bracket than a cherokee? What am I missing? A pic would be worth a thousand words.
GunNut1 is offline
post #2 of 5 Old 02-20-2012, 03:43 PM
imstillatwork
I believe that like the 2.5, they have an idle pully if there is no ac.
I may be wrong though...
imstillatwork is offline
post #3 of 5 Old 02-20-2012, 04:56 PM
fratis
fratis's Avatar
91 4.0 no ac.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 5 Old 02-21-2012, 07:23 AM Thread Starter
GunNut1
Perfect, thanks for the pic, it looks like I need a TJ bracket
GunNut1 is offline
post #5 of 5 Old 02-21-2012, 10:53 AM Thread Starter
GunNut1
Getting a tj bracket is not working out, plus I 'm not sure that's all i will need so, I found a cheaper alternative, Dorman 34171 Air Conditioning Bypass Pulley $29 on amazon
GunNut1 is offline
wheel off set config woodrofosho TJ Wrangler Technical Forum 3 12-19-2010 10:25 PM
what engine config.? army_jeep_2004 YJ Wrangler Technical Forum 1 03-05-2009 07:34 PM
Need advice on lifting/tires/wheel config VAJeepDude JK Wrangler Technical Forum 5 05-05-2008 01:47 PM
Unlimited different top config pics jeremy2027 JK Wrangler Technical Forum 9 03-31-2007 11:39 AM
1988 YJ Belt Config kg6mti YJ Wrangler Technical Forum 4 10-14-2004 05:27 PM
