4.0 vs. 4.2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.0 vs. 4.2
Yukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 03-28-2008, 11:01 PM   #1
Bwick84
1983 CJ5
4.0 vs. 4.2
I have been searching for a YJ with a 6-cylinder for a while now. I've been looking mostly at the 1990's models with the 4.0. I came across a 1987 with the 4.2 and only 92,000 miles on the original motor.
How do the engines compare? Is the 4.2 still very reliable other than some of the carb issues that I have read about?
Do they get similar gas mileage? Any input would be greatly appreciated.
Bwick84 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2008, 11:03 PM   #2
igofshn
Locked @ both ends
igofshn's Avatar
Serious carb issues and less HP than a 2.5 4 cyl TJ. Don't waste your money. Post 91 is what you want.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote Quick reply to this message
Unread 03-28-2008, 11:06 PM   #3
biker8888
i agree. major carb issues. I still haven't found the right setup for mine yet... gas mileage is pretty terrible. The 4.0 is definetly the way to go IMO. One thing I do like is the torque out of my 4.2
biker8888 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2008, 11:27 PM   #4
ElvisV04290
If you want something thats going to work with as little problems as possible, go with the 4.0. Most people I know can't understand why I got a Jeep with a carb and why I don't sell it. If you have not worked with carbs before then chances are you will not like 'em. 4.2's get less mileage than the 4.0 and produce less power, that is true. I keep mine because I like the carb (since I know them) and I wanted something not everyone has, or even wants. In the end, you are going to want a 4.0L, just my guess.
Oh, and 1987-1990 is the 4.2, 1991-1995 is the 4.0 for YJ's.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member www.extremejeepclub.com
Weber 32/36 Install -> http://www.jeepforum.com/forum/f12/weber-32-36-install-write-up-382309/
Early YJ Club Member #37
For anyone with a 4.2L --> http://groups.jeepforum.com/258s_Unite
ElvisV04290 is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 12:09 AM   #5
workinonit
I second what elvis said. you will get more power and better mpg with the newer 4.0.. I just found my 90 4.2 pretty cheep at the time. And I love it!! but as soon as I get the funds I am going to do the 4.0 swap.
90 YJ I6 auto
4" RE lift
33" Trxus on 15x8 crager soft 8s
8.8 rear & 373 gears
still workinonit
workinonit is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 12:15 AM   #6
Blazin Den
If you come across a good deal on one with a 4.2 go for it. You can always do the 4.0 motor swap or even just do the 4.0 head conversion.
I was looking around for a yj with 4.0/automatic in it myself but bought one with the 4cyl/ax-5 because i got it so cheap.
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 07:24 AM   #7
Bwick84
1983 CJ5
Thanks for all the great advice. That is kind of what I thought. This Jeep just happens to be in great shape and you don't find 20+ year old vehicles with only 90K miles on the original motor very often. I don't think I've even been able to find a 4.0 with less than 100K. I think I will just hold out for a 4.0 unless I can talk him down and get it for really cheap. Thanks again.
Unread 03-29-2008, 07:37 AM   #8
xxxflhrci
There is nothing wrong with the 4.2 except the crappy carb on later models. Jeep used the motor for 20 years for a reason. Sure, a 4.2 doesn't have the hp of the 4.0, but it has unmatched bottom end torque that comes off nearly off idle. The 4.2 is rated at 210 ft lbs @ 2000 rpm compared to the 4.0 which is rated at 220 ft lbs @ 4000 rpm
xxxflhrci is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 07:43 AM   #9
igofshn
Locked @ both ends
igofshn's Avatar
solution is PROPANE. www.gotpropane.com I did this to my samurai. Best mod I ever did. purrs like a kitten.
[Jeep Pics
Unread 03-29-2008, 07:46 AM   #10
Brandon_YJ
1987 YJ Wrangler
The 4.2 is a fine engine with plenty of power out of the hole.
I purposefully got a 4.2 with a carb. Sure they can be finicky, but the cost of fixing somehting if it goes bad is much lower than any computer controlled engine.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
Brandon_YJ is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 08:13 AM   #11
roadyrob
1987 YJ Wrangler
when I was looking for my heep, my main priority was a solid body and frame. i found an 87 that had been a motor home tow behind, completly stock, with a poorly running 4.2. swapped out the carb and ignition for a weber and hei. now it runs great, gets about the same gas milage as the 4.0 ( 14-15 around town, 18 highway)
its easy to work on and has plenty of power. the HP and torque are at low rpm's where you can use it. great motor if they are set up right.
roadyrob is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 08:30 AM   #12
Bwick84
1983 CJ5
How much did the weber carb cost you roadyrob? I've never really worked with carbs before, are they hard to install/work with?
Unread 03-29-2008, 09:30 AM   #13
roadyrob
1987 YJ Wrangler
you can get a weber kit for around 300.00. ( I got mine off ebay from a private seller that decided not to use it for 200.00 ) the kit is complete w/linkage, adapter and air cleaner. the instructions are easy to follow. you really need to do the hei distributor also. I got mine from crt on ebay, another 200.00. don't count the 4.2 out, if you can get a deal on a solid jeep, I would use the need for upgrades as a bargaining (sp) point, dollar for dollar a 4.0 is a better deal.
Unread 03-29-2008, 10:59 AM   #14
Beachcruiser
1987 YJ Wrangler
If you can get a low milage 4.0.....it's a great motor, but you do have a lot more stuff to contend with when it starts to go south.
A nicely set up 4.2 rocks! The low end torque is awesome & they are about as complicated as a hammer to work with. & about as reliable, too.
With equal condition motors, I'd base my decision on a rust free body & drivetrain milage....as fixing body work or re-furbishing running gear can get pricey in a hurry.
probably out breaking stuff.
Beachcruiser is offline   Reply With Quote Quick reply to this message
Unread 03-29-2008, 12:52 PM   #15
Brandon_YJ
1987 YJ Wrangler
Originally Posted by Beachcruiser View Post
..they are about as complicated as a hammer to work with. & about as reliable, too.
And alot of times, that's the only tool you need to work on it.
